Key Recovery Attack Against 2.5-Round Pi-Cipher - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a guess and determine attack against some variants of the π-Cipher family of authenticated ciphers. This family of ciphers is a second-round candidate of the CAESAR competition. More precisely, we show a key recovery attack with time complexity little higher than 2^4ω , and low data complexity, against variants of the cipher with ω-bit words, when the internal permutation is reduced to 2.5 rounds. In particular, this gives an attack with time complexity 2^72 against the variant π16-Cipher096 (using 16-bit words) reduced to 2.5 rounds, while the authors claim 96 bits of security with 3 rounds in their second-round submission. Therefore, the security margin for this variant of π-Cipher is very limited. The attack can also be applied to lightweight variants that are not included in the CAESAR proposal, and use only two rounds. The lightweight variants π16-Cipher096 and π16-Cipher128 claim 96 bits and 128 bits of security respectively, but our attack can break the full 2 rounds with complexity 2^72. Finally, the attack can be applied to reduced versions of two more variants of π-Cipher that were proposed in the first-round submission with 4 rounds: π16-Cipher128 (using 16-bit words) and π32-Cipher256 (using 32-bit words). The attack on 2.5 rounds has complexity 2^72 and 2^137 respectively, while the security claim for 4 rounds are 128 bits and 256 bits of security.
PiCipher_FSE16.pdf (553.55 Ko) Télécharger le fichier
hal-01404164 , version 1 (28-11-2016)
Christina Boura, Avik Chakraborti, Gaëtan Leurent, Goutam Paul, Dhiman Saha, et al.. Key Recovery Attack Against 2.5-Round Pi-Cipher. FSE 2016 - 23rd International Conference Fast Software Encryption, Mar 2016, Bochum, Germany. pp.535 - 553, ⟨10.1007/978-3-662-52993-5_27⟩. ⟨hal-01404164⟩
318 Consultations
147 Téléchargements
