New interface
Conference papers
Improved Differential-Linear Cryptanalysis of 7-Round Chaskey with Partitioning
Abstract : In this work we study the security of Chaskey, a recent lightweight MAC designed by Mouha et al., currently being considered for standardization by ISO/IEC and ITU-T. Chaskey uses an ARX structure very similar to SipHash. We present the first cryptanalysis of Chaskey in the single user setting, with a differential-linear attack against 6 and 7 rounds, hinting that the full version of Chaskey with 8 rounds has a rather small security margin. In response to these attacks, a 12-round version has been proposed by the designers. To improve the complexity of the differential-linear cryptanalysis, we refine a partitioning technique recently proposed by Biham and Carmeli to improve the linear cryptanalysis of addition operations. We also propose an analogue improvement of differential cryptanalysis of addition operations. Roughly speaking, these techniques reduce the data complexity of linear and differential attacks, at the cost of more processing time per data. It can be seen as the analogue for ARX ciphers of partial key guess and partial decryption for SBox-based ciphers. When applied to the differential-linear attack against Chaskey, this partitioning technique greatly reduces the data complexity, and this also results in a reduced time complexity. While a basic differential-linear attack on 7 round takes 2^78 data and time (respectively 2^35 for 6 rounds), the improved attack requires only 2^48 data and 2^67 time (respectively 2^25 data and 2^29 time for 6 rounds). We also show an application of the partitioning technique to FEAL-8X, and we hope that this technique will lead to a better understanding of the security of ARX designs.
Document type :
Conference papers
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-01404221
Contributor : Gaëtan Leurent Connect in order to contact the contributor
Submitted on : Monday, November 28, 2016 - 3:05:03 PM
Last modification on : Wednesday, June 8, 2022 - 12:50:05 PM
Long-term archiving on: : Tuesday, March 21, 2017 - 5:58:04 AM
File
Chaskey_EC16.pdf
Identifiers
Collections
Citation
Gaëtan Leurent. Improved Differential-Linear Cryptanalysis of 7-Round Chaskey with Partitioning. EUROCRYPT 2016 - 35th Annual International Conference on the Theory and Applications of Cryptographic , May 2016, Vienna, Austria. pp.344 - 371, ⟨10.1007/978-3-662-49890-3_14⟩. ⟨hal-01404221⟩
Share
Metrics
Record views
159
Files downloads
299
