On integer-valued means and the symmetric maximum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Aequationes Mathematicae Année : 2017
Integer-valued means, satisfying the decomposability condition of Kolmogoroff/Nagumo, are necessarily extremal, i.e., the mean value depends only on the minimal and maximal inputs. To overcome this severe limitation, we propose an infinite family of (weak) integer means based on the symmetric maximum and computation rules. For such means, their value depends not only on extremal inputs, but also on 2nd, 3rd, etc., extremal values as needed. In particular, we show that this family can be characterized by a weak version of decomposability.
integermean2a(1).pdf (120.87 Ko) Télécharger le fichier
hal-01404593 , version 1 (29-11-2016)
Miguel Couceiro, Michel Grabisch. On integer-valued means and the symmetric maximum. Aequationes Mathematicae, 2017, 91 (2), pp.353-371. ⟨10.1007/s00010-016-0460-9⟩. ⟨hal-01404593⟩
Relations
268 Consultations
313 Téléchargements
