Fixed-time stabilization and consensus of nonholonomic systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IET Control Theory and Applications Année : 2016
This paper focuses on the design of fixed-time consensus for multiple unicycle-type mobile agents. A distributed switched strategy, based on local information, is proposed to solve the leader-follower consensus problem for multiple nonholonomic agents in chained form. The switching times and the prescribed convergence time are explicitly given regardless of the initial conditions. Simulation results highlight the efficiency of the proposed method.
Automatique
NH_FT_C V1.pdf (493.29 Ko) Télécharger le fichier
hal-01405104 , version 1 (29-11-2016)
Michael Defoort, Guillaume Demesure, Zongyu Zuo, Andrey Polyakov, Mohamed Djemai. Fixed-time stabilization and consensus of nonholonomic systems. IET Control Theory and Applications, 2016, ⟨10.1049/iet-cta.2016.0094⟩. ⟨hal-01405104⟩
297 Consultations
482 Téléchargements
