Developments in nonholonomic control problems, IEEE Control Systems Magazine, vol.15, issue.6, pp.20-36, 1995. ,
DOI : 10.1109/37.476384
Performance-based reactive navigation for non-holonomic mobile robots, Robotica, vol.13, issue.02, pp.281-290, 2009. ,
DOI : 10.1016/S0005-1098(02)00012-2
Feedback Control of a Nonholonomic Underwater Vehicle With a Constant Desired Configuration, The International Journal of Robotics Research, vol.15, issue.1, pp.24-35, 1996. ,
DOI : 10.1177/027836499601500102
Global tracking control of underactuated ships by Lyapunov's direct method, Automatica, vol.38, issue.2, pp.301-309, 2002. ,
DOI : 10.1016/S0005-1098(01)00199-6
Asymptotic stability and feedback stabilization, in Differential Geometric Control Theory, pp.181-191, 1983. ,
Explicit design of time-varying stabilizing control laws for a class of controllable systems without drift, Systems and Control Letters, pp.147-158, 1992. ,
Nonholonomic motion planning: steering using sinusoids, IEEE Transactions on Automatic Control, vol.38, issue.5, pp.700-716, 1993. ,
DOI : 10.1109/9.277235
Output feedback exponential stabilization of uncertain chained systems, Journal of the Franklin Institute, vol.344, issue.1, pp.36-57, 2007. ,
DOI : 10.1016/j.jfranklin.2005.10.002
Discontinuous control of nonholonomic systems, Systems & Control Letters, vol.27, issue.1, pp.37-45, 1996. ,
DOI : 10.1016/0167-6911(95)00041-0
Integral sliding mode control of an extended Heisenberg system, IET Control Theory & Applications, vol.3, issue.10, pp.1409-1424, 2009. ,
DOI : 10.1049/iet-cta.2007.0480
URL : https://hal.archives-ouvertes.fr/inria-00366042
A Lyapunov-based design of a modified super-twisting algorithm for the Heisenberg system, IMA Journal of Mathematical Control and Information, vol.30, issue.2, pp.185-204, 2013. ,
DOI : 10.1093/imamci/dns020
Flocking for Multi-Agent Dynamic Systems: Algorithms and Theory, IEEE Trans. Aut. Cont, vol.51, issue.3, pp.410-420, 2006. ,
Rendezvous of multiple mobile agents with preserved network connectivity, Systems & Control Letters, vol.59, issue.5, pp.313-322, 2010. ,
DOI : 10.1016/j.sysconle.2010.03.006
Distributed Kalman consensus filter with intermittent observations, Journal of the Franklin Institute, vol.352, issue.9, 2015. ,
DOI : 10.1016/j.jfranklin.2015.01.002
Sliding-Mode Formation Control for Cooperative Autonomous Mobile Robots, IEEE Transactions on Industrial Electronics, vol.55, issue.11, pp.55-3944, 2008. ,
DOI : 10.1109/TIE.2008.2002717
URL : https://hal.archives-ouvertes.fr/inria-00424437
Cascade design for formation control of nonholonomic systems in chained form, Journal of the Franklin Institute, vol.348, issue.6, pp.973-998, 2011. ,
DOI : 10.1016/j.jfranklin.2011.03.008
Distributed finite-time attitude containment control of multi-rigid-body systems, Journal of the Franklin Institute, vol.352, issue.5, pp.2187-2203, 2015. ,
DOI : 10.1016/j.jfranklin.2015.03.017
Consensus seeking in multiagent systems under dynamically changing interaction topologies, IEEE Transactions on Automatic Control, vol.50, issue.5, pp.655-661, 2005. ,
DOI : 10.1109/TAC.2005.846556
Consensus seeking in multiagent systems under dynamically changing interaction topologies, IEEE Transactions on Automatic Control, vol.50, issue.5, pp.655-661, 2007. ,
On Consensus Algorithms for Double-Integrator Dynamics, IEEE Transactions on Automatic Control, vol.53, issue.6, pp.1503-1509, 2008. ,
DOI : 10.1109/TAC.2008.924961
Robust consensus tracking of a class of second-order multi-agent dynamic systems, 49th IEEE Conference on Decision and Control (CDC), pp.134-142, 2012. ,
DOI : 10.1109/CDC.2010.5718101
Consensus of double-integrator multi-agent systems without relative state derivatives under communication noises and directed topologies, Journal of the Franklin Institute, vol.352, issue.3, pp.897-912, 2015. ,
DOI : 10.1016/j.jfranklin.2014.12.001
Designing Fully Distributed Consensus Protocols for Linear Multi-Agent Systems With Directed Graphs, IEEE Transactions on Automatic Control, vol.60, issue.4, pp.1152-1157, 2015. ,
DOI : 10.1109/TAC.2014.2350391
Second-Order Locally Dynamical Consensus of Multiagent Systems With Arbitrarily Fast Switching Directed Topologies, IEEE Transactions on Systems, Man, and Cybernetics: Systems, vol.43, issue.6, pp.1343-1353, 2013. ,
DOI : 10.1109/TSMC.2013.2242466
Self-triggered control for multi-agent systems with unknown non-linear inherent dynamics, IET Control Theory & Applications, vol.8, issue.18, pp.2266-2275, 2014. ,
DOI : 10.1049/iet-cta.2013.0843
Cooperative Control of Multiple Nonholonomic Mobile Agents, IEEE Transactions on Automatic Control, vol.53, issue.6, pp.1434-1448, 2008. ,
DOI : 10.1109/TAC.2008.925852
Leader-following control of multiple nonholonomic systems over directed communication graphs, International Journal of Systems Science, vol.47, issue.8, 2014. ,
DOI : 10.1016/j.sysconle.2012.10.012
Output consensus for multiple non-holonomic systems under directed communication topology, International Journal of Systems Science, vol.46, issue.3, pp.451-463, 2015. ,
DOI : 10.1080/00207721.2012.684903
Finite-Time Consensus Problems for Networks of Dynamic Agents, IEEE Transactions on Automatic Control, vol.55, issue.4, pp.950-955, 2010. ,
DOI : 10.1109/TAC.2010.2041610
Distributed coordinated tracking with reduced interaction via a variable structure approach, IEEE Trans. Aut. Cont, vol.57, issue.1, pp.33-48, 2012. ,
DOI : 10.1109/tac.2010.2049517
Robust Finite-Time Consensus Tracking Algorithm for Multirobot Systems, IEEE/ASME Transactions on Mechatronics, vol.14, issue.2, pp.219-228, 2009. ,
DOI : 10.1109/TMECH.2009.2014057
Finite-time consensus algorithm for multi-agent systems with double-integrator dynamics, Automatica, vol.47, issue.8, pp.47-1706, 2011. ,
DOI : 10.1016/j.automatica.2011.02.045
Finite-time consensus for multi-agent networks with unknown inherent nonlinear dynamics, Automatica, vol.50, issue.10, pp.50-2648, 2014. ,
DOI : 10.1016/j.automatica.2014.08.028
Finite-time formation control of multiple nonholonomic mobile robots, International Journal of Robust and Nonlinear Control, vol.59, issue.12, pp.140-165, 2014. ,
DOI : 10.1002/rnc.2880
Nonlinear Feedback Design for Fixed-Time Stabilization of Linear Control Systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
DOI : 10.1109/TAC.2011.2179869
URL : https://hal.archives-ouvertes.fr/hal-00757561
Distributed robust finite-time nonlinear consensus protocols for multi-agent systems, International Journal of Systems Science, vol.47, issue.6, pp.1-12, 2014. ,
Leader-follower fixed-time consensus for multiagent systems with unknown nonlinear inherent dynamics, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01215015
Nonsingular fixed-time consensus tracking for second-order multi-agent networks, Automatica, vol.54, pp.305-309, 2015. ,
DOI : 10.1016/j.automatica.2015.01.021
Differential equations with discontinuous right-hand side, Kluwer Academic, 1988. ,
DOI : 10.1090/trans2/042/13
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals, and Systems, vol.17, issue.2, pp.101-127, 2005. ,
DOI : 10.1007/s00498-005-0151-x
