Design of Prioritized N-Wise Testing
-wise testing is a widely used technique for combinatorial interaction testing. Prioritizing testing reorders test cases by relevance, testing important aspects more thoroughly. We propose a novel technique for -wise test case generation to satisfy the three distinct prioritization criteria of interaction coverage, weight coverage, and KL divergence. The proposed technique generates small -wise test cases, where high-priority test cases appear early and frequently. Our early evaluation confirms that the proposed technique improves on existing techniques based on the three prioritization criteria.
978-3-662-44857-1_14_Chapter.pdf (358.51 Ko)
Télécharger le fichier
Format : Figure, Image
