Change Detection System for the Maintenance of Automated Testing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Miroslav Bures
  • Fonction : Auteur
  • PersonId : 994815
Maintenance of automated test scripts is one of the important factors leading to success and return of investment of the test automation projects. As the key prerequisite to maintain the scripts correctly, we need to be informed about all relevant changes in the project scope, specification or system under test to be able to reflect them in updates of the test scripts. In this paper we introduce a concept on how to track these changes in semi-automated way with acceptable additional effort. The proposed solution is based on automated detection of changes in test management and requirement management tools, combined with optional manual inputs and automated scanning of changes in system under test user interface.
978-3-662-44857-1_15_Chapter.pdf (148.43 Ko) Télécharger le fichier
hal-01405287 , version 1 (29-11-2016)
Paternité
Miroslav Bures. Change Detection System for the Maintenance of Automated Testing. 26th IFIP International Conference on Testing Software and Systems (ICTSS), Sep 2014, Madrid, Spain. pp.192-197, ⟨10.1007/978-3-662-44857-1_15⟩. ⟨hal-01405287⟩
379 Consultations
167 Téléchargements
