Robust output-control for uncertain linear systems: Homogeneous differentiator-based observer approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2017
This paper deals with the design of a robust control for linear systems with external disturbances using a homogeneous differentiator-based observer based on a implicit Lyapunov function approach. Sufficient conditions for stability of the closed-loop system in the presence of external disturbances are obtained and represented by linear matrix inequalities. The parameter tuning for both controller and observer is formulated as a semi-definite programming problem with linear matrix inequalities constraints. Simulation results illustrate the feasibility of the proposed approach and some improvements with respect to the classic linear observer approach.
_IJRNC.pdf (780.1 Ko) Télécharger le fichier
hal-01405383 , version 1 (02-12-2016)
Hector Ríos, Manuel Mera, Denis Efimov, Andrey Polyakov. Robust output-control for uncertain linear systems: Homogeneous differentiator-based observer approach. International Journal of Robust and Nonlinear Control, 2017, 27 (11), pp.1895-1914. ⟨10.1002/rnc.3643⟩. ⟨hal-01405383⟩
187 Consultations
273 Téléchargements
