An overlook on statistical inference issues for stochastic damping Hamiltonian systems under the fluctuation-dissipation condition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistics Année : 2017
In this paper, we are interested in nonparametric inference issues for stochastic damping hamiltonian systems under the fluctuation-dissipation condition. This condition relates the magnitude of the dissipative term and the magnitude of the random term. The precise balance between the drift term which removes energy in average and the stochastic term provided by the fluctuation-dissipation relation insures that the canonical measure is preserved by the dynamics. In this framework, it is possible to give an explicit construction of a Lyapunov function and thus to prove exponential ergodicity. Then, we consider various estimation procedures and provide also a numerical section, where simulations are conducted.
11_10_16Fluctuationdisipation.pdf (2.08 Mo) Télécharger le fichier
hal-01405427 , version 1 (08-12-2016)
Patrick Cattiaux, Jose Rafael León, Angie Pineda Centeno, Clémentine Prieur. An overlook on statistical inference issues for stochastic damping Hamiltonian systems under the fluctuation-dissipation condition. Statistics, 2017, Special Issue in Honour of Paul Doukhan: Selected Papers from the Conference on the Occasion of Paul Doukhan’s 60th Birthday: Dependence, Limit Theorems and Applications, 51 (1), pp.11-29. ⟨10.1080/02331888.2016.1259807⟩. ⟨hal-01405427⟩
517 Consultations
195 Téléchargements
