Protection Profile for Secure Sensitive Information System on Mobile Devices
The mobility of the user and information is a factor that should be taken into account during the design and development of mechanisms protecting the sensitive stored, exchanged and processed information on mobile devices. This paper discusses the security profiles for the user and dispatcher subsystems protecting sensitive information on the mobile device called MobInfoSec. MobInfoSec is a system providing users with secure sensitive documents by using the specialized class SP cryptographic module, which protects directly the trusted system components through implementing ORCON access control rules. Protection Profile defines the security functional requirements for MobInfoSec system executing the encryption/decryption of documents based on addressed access policies. The article includes a general description of MobInfoSec system, including assets, assumptions, threats, policies and functional requirements necessary for the evaluation of security functions developed in accordance with requirements of the standard ISO/IEC 15408 (called the Common Criteria).
