Feedback sensitivity functions analysis of finite-time stabilizing control system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2016
This paper presents feedback sensitivity functions analysis of implicit Lyapunov function-based control system in case of finite-time stabilization problem. The Gang of Four is chosen as a feedback sensitivity tool. The results can be used for parametric tuning of control algorithms in order to guarantee desired closed-loop sensitivity specifications. The obtained results are supported by numerical examples.
rnc.pdf (1.3 Mo) Télécharger le fichier
hal-01405766 , version 1 (30-11-2016)
D Zimenko, Andrey Polyakov, Denis Efimov, A Kremlev. Feedback sensitivity functions analysis of finite-time stabilizing control system. International Journal of Robust and Nonlinear Control, 2016, ⟨10.1002/rnc.3693⟩. ⟨hal-01405766⟩
107 Consultations
1113 Téléchargements
