IPv6 DOTS Signal Option
This document specifies an optional fall-back opportunistic method that employs the IPv6 Hop-by-Hop options extension header type. It allows a DOTS client to send a signaling message over a congested network due to a DDoS attack by ''tagging'' bypassing outgoing IPv6 packets to reach a DOTS server or gateway.
