New interface
Conference papers
Crosstalk noise aware wavelength allocation in WDM 3D ONoC
Abstract : Optical Network-on-Chip (ONoC) employs Wavelength Division Multiplexing (WDM) supporting multiple transactions at same time. In this context, many senders and receivers can share the same waveguide to increase the total bandwidth utilization. However, simultaneous transmissions on closed adjacent wavelengths may introduce crosstalk noise through different optical switching elements within the network due to the low wavelength channel spacing and the large Full Width at Half Maximum (FWHM) of the resonance pic of the Microring Res-onator (MR). To address this problem, this paper proposes crosstalk noise aware wavelength allocation in WDM 3D ONoC to improve Signal to Noise Ratio (SNR) performance .
Complete list of metadata
https://hal.inria.fr/hal-01406355
Contributor : Daniel Chillet Connect in order to contact the contributor
Submitted on : Thursday, December 1, 2016 - 10:02:26 AM
Last modification on : Saturday, June 25, 2022 - 7:46:01 PM
Long-term archiving on: : Monday, March 20, 2017 - 5:56:11 PM
File
GDR_SoC_SiP_v1.pdf
Identifiers
  • HAL Id : hal-01406355, version 1
Citation
Jiating Luo, Daniel Chillet, Cédric Killian, Sébastien Le Beux, Ian O 'Connor, et al.. Crosstalk noise aware wavelength allocation in WDM 3D ONoC. Colloque National du GDR SoC-SiP, Jun 2016, Nantes, France. ⟨hal-01406355⟩
Share
Metrics
Record views
598
Files downloads
107
