Technical Note???An Exact Algorithm for the Time-Constrained Traveling Salesman Problem, Operations Research, vol.31, issue.5, pp.938-945, 1983. ,
DOI : 10.1287/opre.31.5.938
Nested Monte-Carlo search, IJCAI, pp.456-461, 2009. ,
DOI : 10.1109/ipdps.2009.5161122
URL : https://hal.archives-ouvertes.fr/hal-01436286
Application of the nested rollout policy adaptation algorithm to the traveling salesman problem with time windows', in LION 6, 2012. ,
State-space relaxation procedures for the computation of bounds to routing problems', Networks, pp.145-164, 1981. ,
An Optimal Algorithm for the Traveling Salesman Problem with Time Windows, Operations Research, vol.43, issue.2, pp.367-371, 1995. ,
DOI : 10.1287/opre.43.2.367
A Hybrid Exact Algorithm for the TSPTW, INFORMS Journal on Computing, vol.14, issue.4, pp.403-417, 2002. ,
DOI : 10.1287/ijoc.14.4.403.2827
A Generalized Insertion Heuristic for the Traveling Salesman Problem with Time Windows, Operations Research, vol.46, issue.3, pp.330-335, 1998. ,
DOI : 10.1287/opre.46.3.330
Computational complexity and the traveling salesman problem, Mass. Inst. of Technology Laboratory for Computer Science, 1981. ,
Beam-ACO for the travelling salesman problem with time windows, Computers & Operations Research, vol.37, issue.9, pp.1570-1583, 2010. ,
DOI : 10.1016/j.cor.2009.11.015
An Exact Constraint Logic Programming Algorithm for the Traveling Salesman Problem with Time Windows, Transportation Science, vol.32, issue.1, pp.12-29, 1998. ,
DOI : 10.1287/trsc.32.1.12
The Vehicle Routing Problem with Time Windows Part II: Genetic Search, INFORMS Journal on Computing, vol.8, issue.2, p.165, 1996. ,
DOI : 10.1287/ijoc.8.2.165
Optimization of the nested monte-carlo algorithm on the traveling salesman problem with time windows', Applications of Evolutionary Computation, pp.501-510, 2011. ,
Nested rollout policy adaptation for monte carlo tree search, IJ- CAI, pp.649-654, 2011. ,
Algorithms for the Vehicle Routing and Scheduling Problems with Time Window Constraints, Operations Research, vol.35, issue.2, pp.254-265, 1987. ,
DOI : 10.1287/opre.35.2.254
