Investigating Monte-Carlo Methods on the Weak Schur Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nested Monte-Carlo Search (NMC) and Nested Rollout Policy Adaptation (NRPA) are Monte-Carlo tree search algorithms that have proved their efficiency at solving one-player game problems, such as morpion solitaire or sudoku 16x16, showing that these heuristics could potentially be applied to constraint problems. In the field of Ramsey theory, the weak Schur number WS(k) is the largest integer n for which their exists a partition into k subsets of the integers [1, n] such that there is no x < y < z all in the same subset with x + y = z. Several studies have tackled the search for better lower bounds for the Weak Schur numbers WS(k), k ≥ 4. In this paper we investigate this problem using NMC and NRPA, and obtain a new lower bound for WS(6), namely WS(6) ≥ 582.
evo13.pdf (148.17 Ko) Télécharger le fichier
hal-01406479 , version 1 (01-12-2016)
Shalom Eliahou, Cyril Fonlupt, Jean Fromentin, Virginie Marion-Poty, Denis Robilliard, et al.. Investigating Monte-Carlo Methods on the Weak Schur Problem. EvoCop, Apr 2013, Vienne, Austria. pp.191 - 201, ⟨10.1007/978-3-642-37198-1_17⟩. ⟨hal-01406479⟩
125 Consultations
236 Téléchargements
