Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Featured model-based mutation analysis
Abstract : Model-based mutation analysis is a powerful but expensive testing technique. We tackle its high computation cost by proposing an optimization technique that drastically speeds up the mutant execution process. Central to this approach is the Featured Mutant Model, a modelling framework for mutation analysis inspired by the software product line paradigm. It uses behavioural variability models, viz., Featured Transition Systems, which enable the optimized generation, configuration and execution of mutants. We provide results, based on models with thousands of transitions, suggesting that our technique is fast and scalable. We found that it outperforms previous approaches by several orders of magnitude and that it makes higher-order mutation practically applicable.
Document type :
Conference papers
Complete list of metadata
Cited literature [63 references]  Display  Hide  Download
https://hal.inria.fr/hal-01406512
Contributor : Nisrine JAFRI Connect in order to contact the contributor
Submitted on : Thursday, December 1, 2016 - 2:37:37 PM
Last modification on : Monday, June 27, 2022 - 3:03:05 AM
Links full text
Identifiers
Citation
Xavier Devroey, Gilles Perrouin, Mike Papadakis, Axel Legay, Pierre-yves Schobbens, et al.. Featured model-based mutation analysis. ICSE '16 - 38th International Conference on Software Engineering, May 2016, Austin, United States. pp.655 - 666, ⟨10.1145/2884781.2884821⟩. ⟨hal-01406512⟩
Share
Metrics
Record views
234
