Quantum Expander Codes
We present an efficient decoding algorithm for constant rate quantum hyper graph-product LDPC codes which provably corrects adversarial errors of weight proportional to the code minimum distance, or equivalently to the square-root of the block length. The algorithm runs in time linear in the number of qubits, which makes its performance the strongest to date for linear-time decoding of quantum codes. The algorithm relies on expanding properties, not of the quantum code's factor graph directly, but of the factor graph of the original classical code it is constructed from.
