A Cyclic Reduction Approach to the Numerical Solution of Boundary Value ODEs, SIAM Journal on Scientific Computing, vol.18, issue.1, pp.56-68, 1997. ,
DOI : 10.1137/S1064827595287225
Matrices with Hierarchical Low-Rank Structures, CIME Summer School on Exploiting Hidden Structure in Matrix Computations ,
DOI : 10.1007/978-3-319-49887-4_3
Solution of the matrix equation AX + XB = C [F4], Communications of the ACM, vol.15, issue.9, pp.820-826, 1972. ,
DOI : 10.1145/361573.361582
Efficient cyclic reduction for quasi-birth?death problems with rank structured blocks, Applied Numerical Mathematics, 2016. ,
A modification of the Dewilde???van der Veen method for inversion of finite structured matrices, Special issue on structured and infinite systems of linear equations, pp.419-450, 2002. ,
DOI : 10.1016/S0024-3795(01)00363-9
Separable type representations of matrices and fast algorithms Completion problems. Multiplication and inversion algorithms, Advances and Applications. Birkhäuser, vol.1, issue.234 ,
DOI : 10.1007/978-3-0348-0612-1
Separable type representations of matrices and fast algorithms, of Operator Theory: Advances and Applications. Birkhäuser ,
On the use of matrix functions for fractional partial differential equations, Mathematics and Computers in Simulation, vol.81, issue.5, pp.1045-1056, 2011. ,
DOI : 10.1016/j.matcom.2010.10.009
Multilevel quasiseparable matrices in pdeconstrained optimization, 2011. ,
Numerical solution of parameter-dependent linear systems, Numerical Linear Algebra with Applications, vol.36, issue.9, pp.923-940, 2005. ,
DOI : 10.1002/nla.442
Computing $A^\alpha, \log(A)$, and Related Matrix Functions by Contour Integrals, SIAM Journal on Numerical Analysis, vol.46, issue.5, pp.2505-2523, 2008. ,
DOI : 10.1137/070700607
Decay bounds for the numerical quasiseparable preservation in matrix functions. arXiv preprint, 2016. ,
Expanding the reciprocal of an entire function with zeros in a strip in a Krei??n series, Matematicheskii Sbornik, vol.202, issue.12, pp.137-156, 2011. ,
DOI : 10.4213/sm7771
Extended Krylov subspace for parameter dependent systems, Applied Numerical Mathematics, vol.60, issue.5, pp.550-560, 2010. ,
DOI : 10.1016/j.apnum.2010.03.001
Matrix computations and semiseparable matrices, 2008. ,
DOI : 10.1007/s10092-005-0107-z
Matrix computations and semiseparable matrices Eigenvalue and singular value meth- ods, 2008. ,
An in-core finite difference method for separable boundary value problems on a rectangle, Studies in Applied Mathematics, vol.52, issue.2, pp.103-113, 1973. ,
