A time-space model for the growth of microalgae biofilms for biofuel production - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Theoretical Biology Année : 2017
We present in this paper a spatial model describing the growth of a photosynthetic microalgae biofilm. In this model we consider photosynthesis, extracellular matrix excretion, and mortality. These mechanisms are described precisely using kinetic laws that take into account some saturation effects which limit the reaction rates and involve different components that we treat individually. In particular, to obtain a more detailed description of the microalgae growth, we consider separately the lipids they contain and the functional part of microalgae (proteins, RNA, etc ...), the latter playing a leading role in photosynthesis. We also consider the components dissolved in liquid phase as CO 2. The model is based on mixture theory and the behavior of each component is described on the one hand by mass conservation, which takes into account biological features of the system, and on the other hand by conservation of momentum, which describes the physical properties of the components. Some numerical simulations are displayed in the one-dimensional case and show that the model is able to estimate accurately the biofilm productivity.
Article_Biofilm_1D_031116_hal.pdf (1.19 Mo) Télécharger le fichier
hal-01408045 , version 1 (14-12-2016)
Paternité - Pas d'utilisation commerciale - Partage selon les Conditions Initiales
Bastien Polizzi, O. Bernard, Magali Ribot. A time-space model for the growth of microalgae biofilms for biofuel production. Journal of Theoretical Biology, 2017, ⟨10.1016/j.jtbi.2017.08.017⟩. ⟨hal-01408045⟩
1552 Consultations
479 Téléchargements
