HANASUI: Multi-view Observable and Movable Fogscreen
In this paper, we propose the method for creating multi-view movable fogscreen, and then implement it in our system called “HANASUI”. “HANASUI” displays handheld-like fireworks through a fog screen instead of sparkles. Our method generates projection data dynamically from a virtual space and then casts it with multiple projectors, tracking the marker attached to the device which spouts fog at the fogscreen with infrared cameras and infrared floodlights. Finally, we conducted a survey to verify the capabilities of “HANASUI” and its potential for art and entertainment purposes.
Informatique [cs]
