Algorithms for quantum computation: discrete logarithms and factoring, Proceedings 35th Annual Symposium on Foundations of Computer Science, pp.124-134, 1994. ,
DOI : 10.1109/SFCS.1994.365700
A Public-Key System Based on Algebraic Coding Theory, Jet Propulsion Lab, pp.114-116, 1978. ,
On the inherent intractability of certain coding problems (Corresp.), IEEE Transactions on Information Theory, vol.24, issue.3, pp.384-386, 1978. ,
DOI : 10.1109/TIT.1978.1055873
A distinguisher for high rate McEliece cryptosystems, Proc. IEEE Inf, pp.282-286, 2011. ,
Shorter keys for code based cryptography, Proceedings of the 2005 International Workshop on Coding and Cryptography (WCC 2005), pp.81-91, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00078726
On the use of structured codes in code based cryptography, The Royal Flemish Academy of Belgium for Science and the Arts, pp.59-68, 2010. ,
Algebraic Cryptanalysis of McEliece Variants with Compact Keys, Advances in Cryptology -EUROCRYPT 2010, pp.279-298, 2010. ,
DOI : 10.1007/978-3-642-13190-5_14
MDPC-McEliece: New McEliece variants from Moderate Density Parity-Check codes, 2013 IEEE International Symposium on Information Theory, pp.2069-2073, 2013. ,
DOI : 10.1109/ISIT.2013.6620590
URL : https://hal.archives-ouvertes.fr/hal-00870929
Smaller Keys for Code-Based Cryptography: QC-MDPC McEliece Implementations on Embedded Devices, Cryptographic Hardware and Embedded Systems -CHES 2013, ser. Lecture Notes in, pp.273-292, 2013. ,
DOI : 10.1007/978-3-642-40349-1_16
Lightweight code-based cryptography: QC-MDPC McEliece encryption on reconfigurable devices, Design, Automation & Test in Europe Conference & Exhibition, pp.1-6, 2014. ,
Implementing QC-MDPC McEliece Encryption, ACM Transactions on Embedded Computing Systems, vol.14, issue.3, pp.1-44, 2015. ,
DOI : 10.1145/2700102
Using low density parity check codes in the McEliece cryptosystem, 2000 IEEE International Symposium on Information Theory (Cat. No.00CH37060), p.215, 2000. ,
DOI : 10.1109/ISIT.2000.866513
The intractability of computing the minimum distance of a code, IEEE Transactions on Information Theory, vol.43, issue.6, pp.1757-1766, 1997. ,
DOI : 10.1109/18.641542
The use of information sets in decoding cyclic codes, IEEE Transactions on Information Theory, vol.8, issue.5, pp.5-9, 1962. ,
DOI : 10.1109/TIT.1962.1057777
A method for finding codewords of small weight, " in Coding Theory and Applications, ser. Lecture Notes in, pp.106-113, 1988. ,
Decoding random linear codes in O(2 0.054n ), Advances in Cryptology -ASIACRYPT 2011, pp.107-124, 2011. ,
DOI : 10.1007/978-3-642-25385-0_6
Decoding Random Binary Linear Codes in 2 n/20: How 1???+???1???=???0 Improves Information Set Decoding, Advances in Cryptology -EUROCRYPT 2012, ser. Lecture Notes in Comput. Sci, 2012. ,
DOI : 10.1007/978-3-642-29011-4_31
On Computing Nearest Neighbors with Applications to Decoding of Binary Linear Codes, Advances in Cryptology - EUROCRYPT 2015, pp.203-228, 2015. ,
DOI : 10.1007/978-3-662-46800-5_9
MDPC-McEliece: New McEliece variants from Moderate Density Parity-Check codes, 2013 IEEE International Symposium on Information Theory, 2012. ,
Low-density parity-check codes, IEEE Transactions on Information Theory, vol.8, issue.1, 1963. ,
DOI : 10.1109/TIT.1962.1057683
