Stability analysis of heterogeneous Helmholtz problems and finite element solution based on propagation media approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2017
The numerical simulation of time-harmonic waves in heterogeneous media is a tricky task which consists in reproducing oscillations. These oscillations become stronger as the frequency increases, and high-order finite element methods have demonstrated their capability to reproduce the oscilla-tory behavior. However, they keep coping with limitations in capturing fine scale heterogeneities. We propose a new approach which can be applied in highly heterogeneous propagation media. It consists in constructing an approximate medium in which we can perform computations for a large variety of frequencies. The construction of the approximate medium can be understood as applying a quadrature formula locally. We establish estimates which generalize existing estimates formerly obtained for homogeneous Helmholtz problems. We then provide numerical results which illustrate the good level of accuracy of our solution methodology.
preprint_mcom.pdf (1.27 Mo) Télécharger le fichier
hal-01408934 , version 1 (12-02-2018)
Hélène Barucq, Théophile Chaumont-Frelet, Christian Gout. Stability analysis of heterogeneous Helmholtz problems and finite element solution based on propagation media approximation. Mathematics of Computation, 2017, 86 (307), pp.2129 - 2157. ⟨10.1090/mcom/3165⟩. ⟨hal-01408934⟩
278 Consultations
356 Téléchargements
