New interface
Book sections
Electroencephalography Data Preprocessing
Abstract : Electroencephalography provides measurements of electrical potential in the form of a time signal for each electrode. Although they only partially reflect the brain's underlying electrophysiological phenomena, these measurements contain a significant amount of information, which is used in clinical diagnosis and cognitive sciences, as well brain computer interfaces. Statistical analysis is also necessary to assess the stability of the information extracted with respect to different parameters. The sampling frequency determines the temporal resolution of observable phenomena, as well as the extent of the analyzable frequency spectrum. Brain-computer interfaces (BCI) is more common for marking to be performed automatically during acquisition. A low-pass filter removes high frequencies, eliminating some sources of noise, such as electrical activity coming from muscles. Statistical representations are useful for analyzing sets of signals measured simultaneously or through several trials. It is certainly also interesting to apply them retrospectively to interpret brain activity modifications occurring before, during and after BCI use.
Document type :
Book sections
Complete list of metadata
https://hal.inria.fr/hal-01409009
Contributor : Maureen Clerc Connect in order to contact the contributor
Submitted on : Monday, December 5, 2016 - 3:54:00 PM
Last modification on : Saturday, June 25, 2022 - 11:24:36 PM
Identifiers
Collections
Citation
Maureen Clerc. Electroencephalography Data Preprocessing. Maureen Clerc; Laurent Bougrain; Fabien Lotte. Brain-Computer Interfaces 1, Wiley-ISTE, 2016, 978-1-84821-826-0. ⟨10.1002/9781119144977.ch6⟩. ⟨hal-01409009⟩
Share
Metrics
Record views
164
