Betti Numbers and Generalized Hamming Weights
We can associate to each linear code C defined over a finite field the matroid M[H] of its parity check matrix H. For any matroid M one can define its generalized Hamming weights which are the same as those of the code C. In [2] the authors show that the generalized Hamming weights of a matroid are determined by the N-graded Betti numbers of the Stanley-Reisner ring of the simplicial complex whose faces are the independent set of M. In this talk we go a step further. Our practical results indicate that the generalized Hamming weights of a linear code C can be obtained from the monomial ideal associated with a test-set for C. Moreover, recall that in [3] we use the Gröbner representation of a linear code C to provide a test-set for C. Our results are still a work in progress, but its applications to Coding Theory and Cryptography are of great value.
