New interface
Poster communications
Building an IEEE 802.15.4e TSCH network
Abstract : —Most wireless sensor networks that are currently deployed use a technology based on the IEEE 802.15.4 standard. However, this standard does not meet all requirements of industrial applications in terms of latency, throughput and robustness. That is why the IEEE 802.15.4e amendment has been designed, including the Time Slotted Channel Hopping (TSCH) mode. In this paper, we focus on how to build a TSCH network and evaluate the time needed to form the network, using the NS3 simulator. A new beacon advertising algorithm is proposed for TSCH networks. A comparative performance evaluation with solutions already published is done.
Document type :
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/hal-01410080
Contributor : Ines Khoufi Connect in order to contact the contributor
Submitted on : Tuesday, December 6, 2016 - 1:49:12 PM
Last modification on : Tuesday, October 25, 2022 - 4:18:38 PM
Long-term archiving on: : Monday, March 20, 2017 - 11:09:07 PM
File
building-ieee-802 (4).pdf
Identifiers
  • HAL Id : hal-01410080, version 1
Collections
Citation
Ines Khoufi, Pascale Minet, Erwan Livolant, Badr Rmili. Building an IEEE 802.15.4e TSCH network. 35th IEEE -- International Performance Computing and Communications Conference, Dec 2016, Las Vegas, United States. ⟨hal-01410080⟩
Share
Metrics
Record views
194
Files downloads
701
