Iterative aggregation and disaggregation algorithm for pseudo-polynomial network flow models with side constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Operational Research Année : 2017
This paper develops a general solution framework based on aggregation techniques to solve NP-Hard problems that can be formulated as a circulation model with specific side constraints. The size of the extended Mixed Integer Linear Programming formulation is generally pseudo-polynomial. To efficiently solve exactly these large scale models, we propose a new iterative aggregation and disaggregation algorithm. At each iteration, it projects the original model onto an aggregated one, producing an approximate model. The process iterates to refine the current aggregated model until the opti-mality is proved. The computational experiments on two hard optimization problems (a variant of the vehicle routing problem and the cutting-stock problem) show that a generic implementation of the proposed framework allows us to out-perform previous known methods.
two_ida.pdf (448.92 Ko) Télécharger le fichier
hal-01410170 , version 1 (31-01-2017)
hal-01410170 , version 2 (24-03-2020)
François Clautiaux, Said Hanafi, Rita Macedo, Marie-Emilie Voge, Cláudio Alves. Iterative aggregation and disaggregation algorithm for pseudo-polynomial network flow models with side constraints. European Journal of Operational Research, 2017, 258, pp.467 - 477. ⟨10.1016/j.ejor.2016.09.051⟩. ⟨hal-01410170v2⟩
351 Consultations
587 Téléchargements
