Dual-Optimal Inequalities for Stabilized Column Generation, Operations Research, vol.54, issue.3, pp.454-463, 2006. ,
DOI : 10.1287/opre.1060.0278
Cutting stock problems, Column Generation, pp.131-161, 2005. ,
Stabilized dynamic constraint aggregation for solving set partitioning problems, European Journal of Operational Research, vol.223, issue.2, 2012. ,
DOI : 10.1016/j.ejor.2012.07.004
Comparison of bundle and classical column generation, Mathematical Programming, pp.299-344, 2008. ,
DOI : 10.1007/s10107-006-0079-z
URL : https://hal.archives-ouvertes.fr/inria-00342510
Lower bounds and algorithms for the 2-dimensional vector packing problem, Discrete Applied Mathematics, vol.111, issue.3, pp.231-262, 2001. ,
DOI : 10.1016/S0166-218X(00)00267-5
Using Extra Dual Cuts to Accelerate Column Generation, INFORMS Journal on Computing, vol.17, issue.2, pp.175-182, 2005. ,
DOI : 10.1287/ijoc.1030.0060
A survey of dual-feasible and superadditive functions, Annals of Operations Research, vol.183, issue.6, pp.317-342, 2009. ,
DOI : 10.1007/s10479-008-0453-8
URL : https://hal.archives-ouvertes.fr/inria-00522674
New Stabilization Procedures for the Cutting Stock Problem, INFORMS Journal on Computing, vol.23, issue.4, pp.530-545, 2011. ,
DOI : 10.1287/ijoc.1100.0415
Stabilized column generation, Discrete Mathematics, vol.194, issue.1-3, pp.229-237, 1999. ,
DOI : 10.1016/S0012-365X(98)00213-1
Multi-phase dynamic constraint aggregation for set partitioning type problems, Mathematical Programming, pp.345-370, 2010. ,
DOI : 10.1007/s10107-008-0254-5
Dynamic Aggregation of Set-Partitioning Constraints in Column Generation, Operations Research, vol.53, issue.4, pp.632-645, 2005. ,
DOI : 10.1287/opre.1050.0222
Heuristics and lower bounds for the bin packing problem with conflicts, Computers & Operations Research, vol.31, issue.3, pp.347-358, 2004. ,
DOI : 10.1016/S0305-0548(02)00195-8
A Linear Programming Approach to the Cutting-Stock Problem, Operations Research, vol.9, issue.6, pp.849-859, 1961. ,
DOI : 10.1287/opre.9.6.849
A Linear Programming Approach to the Cutting Stock Problem???Part II, Operations Research, vol.11, issue.6, pp.863-888, 1963. ,
DOI : 10.1287/opre.11.6.863
Mathematical Methods of Organizing and Planning Production, Management Science, vol.6, issue.4, pp.363-422, 1960. ,
DOI : 10.1287/mnsc.6.4.366
Aggregation in large-scale optimization, 2003. ,
DOI : 10.1007/978-1-4419-9154-6
Selected Topics in Column Generation, Operations Research, vol.53, issue.6, pp.1007-1023, 2005. ,
DOI : 10.1287/opre.1050.0234
Bin packing with items uniformly distributed over intervals [a,b], 24th Annual Symposium on Foundations of Computer Science (sfcs 1983), pp.289-297, 1983. ,
DOI : 10.1109/SFCS.1983.9
Solving the vehicle routing problem with time windows and multiple routes exactly using a pseudo-polynomial model, European Journal of Operational Research, vol.214, issue.3, pp.536-545, 2011. ,
DOI : 10.1016/j.ejor.2011.04.037
URL : https://hal.archives-ouvertes.fr/hal-00616366
Method for Large-Scale Optimization, Operations Research, vol.23, issue.3, pp.389-405, 1975. ,
DOI : 10.1287/opre.23.3.389
An exact algorithm for a single-vehicle routing problem with time windows and multiple routes, European Journal of Operational Research, vol.178, issue.3, pp.755-766, 2007. ,
DOI : 10.1016/j.ejor.2006.02.019
Stabilized column generation for highly degenerate multiple-depot vehicle scheduling problems, Computers & Operations Research, vol.34, issue.3, pp.817-834, 2007. ,
DOI : 10.1016/j.cor.2005.05.011
Column Generation for Extended Formulations, Electronic Notes in Discrete Mathematics, vol.37, pp.357-362, 2011. ,
DOI : 10.1016/j.endm.2011.05.061
URL : https://hal.archives-ouvertes.fr/hal-00661758
Bison: A fast hybrid procedure for exactly solving the one-dimensional bin packing problem, Computers & Operations Research, vol.24, issue.7, pp.627-645, 1997. ,
DOI : 10.1016/S0305-0548(96)00082-2
Solving large-scale linear programs by aggregation, Computers & Operations Research, vol.14, issue.5, pp.385-393, 1987. ,
DOI : 10.1016/0305-0548(87)90035-9
Computational study of a column generation algorithm for bin packing and cutting stock problems, Mathematical Programming, vol.86, issue.3, pp.565-594, 1999. ,
DOI : 10.1007/s101070050105
A generic view of Dantzig???Wolfe decomposition in mixed integer programming, Operations Research Letters, vol.34, issue.3, pp.296-306, 2006. ,
DOI : 10.1016/j.orl.2005.05.009
URL : https://hal.archives-ouvertes.fr/inria-00342623
Approximate extended formulations, Mathematical Programming, pp.501-522, 2006. ,
DOI : 10.1007/s10107-005-0663-7
