Coqoon - Archive ouverte HAL Access content directly
Journal Articles International Journal on Software Tools for Technology Transfer Year : 2017
Coqoon
(1) , (1) , (2) , (3)
1
2
3
User interfaces for interactive proof assistants have always lagged behind those for mainstream programming languages. Whereas integrated development environments (IDEs) have support for features like project management, version control, dependency analysis and incremental project compilation, " IDE " s for proof assistants typically only operate on files in isolation, relying on external tools to integrate those files into larger projects. In this paper we present Coqoon, an IDE for Coq projects integrated into Eclipse. Coqoon manages proofs as projects rather than isolated source files, and compiles these projects using the Eclipse common build system. Coqoon takes advantage of the latest features of Coq, including asynchronous and parallel processing of proofs, and—when used together with a third-party OCaml extension for Eclipse—can even be used to work on large developments containing Coq plugins.
main-sttt.pdf (472.99 Ko) Télécharger le fichier
Dates and versions
hal-01410450 , version 1 (06-12-2016)
Identifiers
  • HAL Id : hal-01410450 , version 1
Cite
Alexander Faithfull, Jesper Bengtson, Enrico Tassi, Carst Tankink. Coqoon. International Journal on Software Tools for Technology Transfer, 2017. ⟨hal-01410450⟩
136 View
141 Download
Share
