A simple finite-time observer for linear time-delay systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a finite-time observer for linear time-delay systems with commensurate delay. Unlike the existing observers in the literature which converges asymptotically, the proposed observer provides a finite-time estimation. This is realized by using the well-known sliding mode technique. Simulation results are also presented in order to illustrate the feasibility of the proposed method.
Automatique
Fichier non déposé
hal-01410836 , version 1 (06-12-2016)
Gang Zheng, Haoping Wang. A simple finite-time observer for linear time-delay systems. VSS 2016 - 14th International Workshop on Variable Structure Systems, IFAC, Mar 2016, Nanjing, China. ⟨10.1109/VSS.2016.7506887⟩. ⟨hal-01410836⟩
93 Consultations
0 Téléchargements
