Observer design for a class of nonlinear singular systems
This paper investigates observer design problem for a large
class of nonlinear singular systems with multi outputs. We
firstly regularize the singular system by injecting the
derivative of outputs into the system. Then differential
geometric method is applied to transform the regularized
system into a simple normal form, for which a
Luenberger-like observer is proposed
