The role of the Hessian matrix in fitting models to measurements, J. Geophys. Res, vol.94, issue.C5, pp.6177-6196, 1989. ,
On analysis error covariances in variational data assimilation, SIAM J. Sci. Computing, vol.30, issue.4, pp.1847-1874, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00391893
Some basic formalism in numerical variational analysis, Month. Wea. Rev, vol.98, issue.12, pp.875-883, 1970. ,
, Stochastic Processes and Filtering Theory, 1970.
Bayesian inverse problems for functions and applications to fluid mechanics, Inverse Problems, vol.25, pp.1-43, 2009. ,
An optimal control problem of initial data restoration, Computational Mathematics and Mathematical Physics, vol.39, issue.9, pp.1416-1425, 1999. ,
On deterministic error analysis in variational data assimilation, Nonlinear Processes in Geophysics, vol.12, pp.481-490, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00331085
Properties of advection algorithms in the context of variational data assimilation, Q.J.R. Meteorol. Soc, vol.129, pp.1221-1231, 2001. ,
The effect of numerical model error on data assimilation, Comp. Appl. Math, vol.290, pp.567-588, 2015. ,
Regularization of incorrectly posed problems, Soviet Math. Dokl, vol.4, pp.1624-1627, 1963. ,
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.38, issue.2, pp.97-110, 1986. ,
Coping with model error in variational data assimilation using optimal mass transport, Water Resour. Res, vol.50, pp.5817-5830, 2014. ,
A variational continuous assimilation technique, Mon. Weather Rev, vol.117, pp.2437-2446, 1989. ,
Model-error estimation in 4D-Var, Q.J.R. Meteorol. Soc, vol.133, issue.626, pp.1267-1280, 2007. ,
Accounting for model error in variational data assimilation: a deterministic approach, Month. Wea. Rev, vol.138, pp.875-883, 2010. ,
On discretization error and its control in variational data assimilation, Tellus, vol.60, pp.979-991, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00391879
Adjoint methods in data assimilation for estimating model error, Flow, Turbulence and Combustion, vol.65, issue.3/4, pp.469-488, 2000. ,
Accounting for model error in data assimilation using adjoint methods, Computational Differentiation: Techniques, Applications and Tools, pp.195-204, 1996. ,
Variational data analysis with control of the forecast bias, Tellus A, vol.56, pp.1-12, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00325592
Different approaches to model error formulation in 4D-Var: a study with high resolution advection schemes, Tellus, vol.61, pp.112-128, 2009. ,
Vers une prise en compte des erreurs-modèle en assimilation de données 4D-variationnelle. Applicationà un modèle réaliste d'océan, 2001. ,
4D Variational Data Analysis with Imperfect Model, Flow, Turbulence and Combustion, vol.65, issue.3-4, pp.489-504, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00325356
Determination of optimal nudging coefficients, Tellus A, vol.55, pp.1-15, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00325360
Vecteurs caractéristiques de modèles océaniques pour la réduction d'ordre en assimilation de données, 2001. ,
Accounting for an imperfect model in 4D-Var, Q.J.R. Meteorol. Soc, vol.132, issue.621, pp.2483-2504, 2006. ,
A moving horizon state estimation algorithm applied to the tennessee eastman benchmark process, IEEE International Conference on Multisensor Fusion and Integration for Intelligent Systems, pp.377-382, 2006. ,
Nouvelle approche des méthodes d'assimilation de données: les algorithmes de point selle, 2000. ,
Long Window 4D-Var, Proceedings of the ECMWF Seminar Series on Data assimilation for atmosphere and ocean, pp.189-202, 2011. ,
Numerical Heat Transfer and Fluid Flow, 1980. ,
On optimal solution error covariances in variational data assimilation problems, Journal of Computational Physics, vol.229, issue.6, pp.2159-2178, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00787292
Guide: Solution of Large-Scale Eigenvalue Problems with Implicitly Restarted Arnoldi Methods. SIAM, 1998. ,
TAPENADE 2.1 user's guide, INRIA Technical Report, issue.0300, pp.1-78, 2004. ,
, Numerical recipes in Fortran 77: the art of scientific computing, 1992.
