On constructing permutations of finite fields, Finite Fields Appl, pp.51-67, 2011. ,
Permutation and complete permutation polynomials, Finite Fields Appl, pp.198-211, 2015. ,
DOI : 10.1016/j.ffa.2014.11.010
Monomial functions with linear structure and permutation polynomials, Contemp. Math, vol.518, pp.99-111, 2010. ,
DOI : 10.1090/conm/518/10199
When does G(x) + ? T r(H(x)) permute F 2 n ? Finite Fields Appl, pp.615-632, 2009. ,
Sparse permutations with low differential uniformity, Finite Fields and Their Applications, vol.28, pp.214-243, 2014. ,
DOI : 10.1016/j.ffa.2014.02.003
URL : https://hal.archives-ouvertes.fr/hal-01068860
Involutions Over the Galois Field, IEEE Transactions on Information Theory, vol.62, issue.4, pp.2266-2276, 2016. ,
DOI : 10.1109/TIT.2016.2526022
URL : https://hal.archives-ouvertes.fr/hal-01272943
Polynomials With Linear Structure and Maiorana–McFarland Construction, IEEE Transactions on Information Theory, vol.57, issue.6, pp.3796-3804, 2011. ,
DOI : 10.1109/TIT.2011.2133690
Permutation polynomials over finite fields A survey of recent advances, Finite Fields Appl, pp.82-119, 2015. ,
Constructing permutations of finite fields via linear translators, Journal of Combinatorial Theory, Series A, vol.118, issue.3, pp.1052-1061, 2011. ,
DOI : 10.1016/j.jcta.2010.08.005
Finite Fields, Encyclopedia Math, Appl, vol.20, 1983. ,
Permutation polynomials in one variable, Chapter 8 in Handbook of Finite Fields, pp.215-230 ,
On derivatives of polynomials over finite fields through integration Available at Cryptology ePrint Archive ,
On the inverses of some classes of permutations of finite fields, Finite Fields and Their Applications, vol.28, pp.244-281, 2014. ,
DOI : 10.1016/j.ffa.2014.02.006
Two classes of permutation polynomials having the form <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msup><mml:mrow><mml:mo stretchy="false">(</mml:mo><mml:msup><mml:mrow><mml:mi>x</mml:mi></mml:mrow><mml:mrow><mml:msup><mml:mrow><mml:mn>2</mml:mn></mml:mrow><mml:mrow><mml:mi>m</mml:mi></mml:mrow></mml:msup></mml:mrow></mml:msup><mml:mo>+</mml:mo><mml:mi>x</mml:mi><mml:mo>+</mml:mo><mml:mi>??</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:mrow><mml:mrow><mml:mi>s</mml:mi></mml:mrow></mml:msup><mml:mo>+</mml:mo><mml:mi>x</mml:mi></mml:math>, Finite Fields and Their Applications, vol.31, pp.12-24, 2015. ,
DOI : 10.1016/j.ffa.2014.09.005
Several classes of complete permutation polynomials, Finite Fields Appl, pp.182-193, 2014. ,
Two classes of permutation polynomials having the form (x 2 m + x + ?) s + x. Finite Fields Appl, pp.12-24, 2015. ,
Some classes of monomial complete permutation polynomials over finite fields of characteristic two, Finite Fields Appl, pp.148-165, 2014. ,
Further results on permutation polynomials over finite fields, Finite Fields Appl, pp.88-103, 2014. ,
DOI : 10.1016/j.ffa.2014.01.006
Permutation polynomials of the form (x p ? x + ?) s + L(x). Finite Fields Appl, pp.482-493, 2008. ,
