A bounded memory allocator for software-defined global address spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a memory allocator targeting manycore architectures with distributed memory. Among the family of Multi Processor System on Chip (MPSoC), these devices are composed of multiple nodes linked by an on-chip network; most nodes have multiple processors sharing a small local memory. While MPSoC typically excel on their performance-per-Watt ratio, they remain hard to program due to multilevel parallelism, explicit resource and memory management, and hardware constraints (limited memory, network topology). Typical programming frameworks for MPSoC leave much target-specific work to the programmer: combining threads or node-local OpenMP, software caching, explicit message passing (and sometimes, routing), with non-standard interfaces. More abstract, automatic frameworks exist, but they target large-scale clusters and do not model the hardware constraints of MPSoC. The memory allocator described in this paper is one component of a larger runtime system, called Givy, to support dynamic task graphs with automatic software caching and data-driven execution on MPSoC. To simplify the programmer's view of memory, both runtime and program data objects live in a Global Address Space (GAS). To avoid address collisions when objects are dynamically allocated, and to manage virtual memory mappings across nodes, a GAS-aware memory allocator is required. This paper proposes such an allocator with the following properties: (1) it is free of inter-node synchronizations; (2) its node-local performance match that of state-of-the-art shared-memory allocators; (3) it provides node-local mechanisms to implement inter-node software caching within a GAS; (4) it is well suited for small memory systems (a few MB per node).
Fichier non déposé
hal-01412919 , version 1 (09-12-2016)
  • HAL Id : hal-01412919 , version 1
François Gindraud, Fabrice Rastello, Albert Cohen, François Broquedis. A bounded memory allocator for software-defined global address spaces. ISMM 2016 - 2016 ACM SIGPLAN International Symposium on Memory Management, Jun 2016, Santa Barbara, United States. ⟨hal-01412919⟩
268 Consultations
0 Téléchargements
