Constrained Markov Decision Processes, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00074109
Learning to act using real-time dynamic programming, Artificial Intelligence, vol.72, issue.1-2, 1995. ,
DOI : 10.1016/0004-3702(94)00011-O
URL : http://doi.org/10.1016/0004-3702(94)00011-o
Dynamic Programming and Optimal Control Volumes), 1995. ,
Planning as heuristic search, Artificial Intelligence, vol.129, issue.1-2, 2001. ,
DOI : 10.1016/S0004-3702(01)00108-4
Labeled RTDP: Improving the convergence of real-time dynamic programming, p.3, 2003. ,
Learning depth-first search: A unified approach to heuristic search in deterministic and non-deterministic settings, and its application to MDPs, p.6, 2006. ,
From FOND to robust probabilistic planning: Computing compact policies that bypass avoidable deadends, p.16, 2016. ,
A survey of the 7th international planning competition. AI Magazine. Coles, A. J. 2012. Opportunistic branched plans to maximise utility in the presence of resource uncertainty, ECAI'12, 2012. ,
Topological value iteration algorithms, 2011. ,
Model minimization in markov decision processes, p.97, 1997. ,
Deterministic oversubscription planning as heuristic search: Abstractions and reformulations, 2015. ,
Boundedparameter Markov decision processes, 2000. ,
LAO???: A heuristic search algorithm that finds solutions with loops, Artificial Intelligence, vol.129, issue.1-2, 2001. ,
DOI : 10.1016/S0004-3702(01)00106-0
URL : http://doi.org/10.1016/s0004-3702(01)00106-0
Landmarks, critical paths and abstractions: What's the difference anyway?, 2009. ,
The Fast Downward planning system, 2006. ,
The FF planning system: Fast plan generation through heuristic search, 2001. ,
Simulated penetration testing: From " Dijkstra " to " Turing Test++, p.15, 2015. ,
Revisiting risk-sensitive MDPs: New algorithms and results, p.14, 2014. ,
Heuristic search for generalized stochastic shortest path MDPs ICAPS'11. Kolobov, A.; Mausam; and Weld Sixthsense: Fast and reliable recognition of dead ends in MDPs. AAAI'10. Kolobov, A.; Mausam; and Weld, D. S. 2012. A theory of goal-oriented MDPs with dead ends, SARSOP: Efficient point-based POMDP planning by approximating optimally reachable belief spaces. Robotics: Science and Systems IV, 2008. ,
Towards faster planning with continuous resources in stochastic domains AAAI-08 Bounded real-time dynamic programming: RTDP with monotone upper bounds and performance guarantees, ICML'05, 2005. ,
A heuristic search approach to planning with continuous resources in stochastic domains, 2009. ,
Improved non-deterministic planning by exploiting state relevance, p.12, 2012. ,
Resourceconstrained planning: A monte carlo random walk approach, p.12, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00765030
POMDPs make better hackers: Accounting for uncertainty in penetration testing AAAI'12 Focused real-time dynamic programming for MDPs: Squeezing more out of a heuristic Revisiting goal probability analysis in probabilistic planning (technical report) Saarland University, AAAI'06. Steinmetz, 2006. ,
Incremental plan aggregation for generating policies in MDPs, p.10, 2010. ,
Stochastic safest and shortest path problems, 2012. ,
FF-Replan: a baseline for probabilistic planning The first probabilistic track of the international planning competition, 2005. ,
