Constrained Markov Decision Processes, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00074109
Controller Synthesis for Probabilistic Systems (Extended Abstract), pp.493-506, 2004. ,
DOI : 10.1007/1-4020-8141-3_38
Learning to act using real-time dynamic programming, Artificial Intelligence, vol.72, issue.1-2, pp.81-138, 1995. ,
DOI : 10.1016/0004-3702(94)00011-O
Dynamic Programming and Optimal Control Volumes), 1995. ,
Neurodynamic Programming, 1996. ,
Planning as heuristic search, Artificial Intelligence, vol.129, issue.1-2, pp.5-33, 2001. ,
DOI : 10.1016/S0004-3702(01)00108-4
URL : http://doi.org/10.1016/s0004-3702(01)00108-4
Faster heuristic search algorithms for planning with uncertainty and full feedback, Proceedings of the 18th International Joint Conference on Artificial Intelligence (IJCAI'03), pp.1233-1238, 2003. ,
Labeled RTDP: Improving the convergence of real-time dynamic programming, Proceedings of the 13th International Conference on Automated Planning and Scheduling (ICAPS'03), pp.12-21, 2003. ,
mgpt: A probabilistic planner based on heuristic search, Journal of Artificial Intelligence Research, vol.24, pp.933-944, 2005. ,
Learning depth-first search: A unified approach to heuristic search in deterministic and non-deterministic settings, and its application to MDPs, Proceedings of the 16th International Conference on Automated Planning and Scheduling (ICAPS'06), pp.142-151, 2006. ,
Action selection for MDPs: Anytime AO* versus UCT, Proceedings of the 26th AAAI Conference on Artificial Intelligence (AAAI'12), 2012. ,
6th international planning competition: Uncertainty part, Proceedings of the 6th International Planning Competition (IPC'08), 2008. ,
From FOND to robust probabilistic planning: Computing compact policies that bypass avoidable deadends, Proceedings of the 26th International Conference on Automated Planning and Scheduling (ICAPS'16, 2016. ,
Optimal cost almost-sure reachability in POMDPs, Proceedings of the 29th AAAI Conference on Artificial Intelligence (AAAI'15), pp.3496-3502, 2015. ,
DOI : 10.1016/j.artint.2016.01.007
Optimal cost almost-sure reachability in POMDPs, Artificial Intelligence, vol.234, pp.26-48, 2016. ,
Opportunistic branched plans to maximise utility in the presence of resource uncertainty, Proceedings of the 20th European Conference on Artificial Intelligence (ECAI'12), pp.252-257, 2012. ,
A hybrid LP-RPG heuristic for modelling numeric resource flows in planning, Journal of Artificial Intelligence Research, vol.46, pp.343-412, 2013. ,
A survey of the seventh international planning competition. The AI Magazine, 2012. ,
Topological value iteration algorithms, Journal of Artificial Intelligence Research, vol.42, pp.181-209, 2011. ,
Model minimization in markov decision processes, Proceedings of the 14th National Conference of the American Association for Artificial Intelligence (AAAI'97), pp.106-111, 1997. ,
Deterministic oversubscription planning as heuristic search: Abstractions and reformulations, Journal of Artificial Intelligence Research, vol.52, pp.97-169, 2015. ,
Directed model checking with distance-preserving abstractions, International Journal on Software Tools for Technology Transfer, vol.1, issue.9, pp.27-37, 2009. ,
DOI : 10.1007/s10009-008-0092-z
Planning with pattern databases, Proceedings of the 6th European Conference on Planning (ECP'01), pp.13-24, 2001. ,
Pruning methods for optimal delete-free planning, Proceedings of the 22nd International Conference on Automated Planning and Scheduling (ICAPS'12, 2012. ,
Bounded-parameter Markov decision processes, Artificial Intelligence, vol.122, issue.1-2, pp.71-109, 2000. ,
DOI : 10.1016/S0004-3702(00)00047-3
URL : http://doi.org/10.1016/s0004-3702(00)00047-3
LAO???: A heuristic search algorithm that finds solutions with loops, Artificial Intelligence, vol.129, issue.1-2, pp.35-62, 2001. ,
DOI : 10.1016/S0004-3702(01)00106-0
Domain-independent construction of pattern database heuristics for cost-optimal planning, Proceedings of the 22nd National Conference of the American Association for Artificial Intelligence (AAAI'07), pp.1007-1012, 2007. ,
Heuristic planning with time and resources, Proceedings of the 6th European Conference on Planning (ECP'01), pp.121-132, 2001. ,
The Fast Downward planning system, Journal of Artificial Intelligence Research, vol.26, pp.191-246, 2006. ,
Landmarks, critical paths and abstractions: What's the difference anyway, Proceedings of the 19th International Conference on Automated Planning and Scheduling (ICAPS'09), pp.162-169, 2009. ,
Merge-and-Shrink Abstraction, Journal of the ACM, vol.61, issue.3, p.61, 2014. ,
DOI : 10.1145/2559951
URL : https://hal.archives-ouvertes.fr/inria-00592438
Simulated penetration testing: From " Dijkstra " to " Turing Test++, Proceedings of the 25th International Conference on Automated Planning and Scheduling (ICAPS'15, 2015. ,
Distance " ? Who Cares? Tailoring merge-andshrink heuristics to detect unsolvability, Proceedings of the 21st European Conference on Artificial Intelligence (ECAI'14), 2014. ,
The FF planning system: Fast plan generation through heuristic search, Journal of Artificial Intelligence Research, vol.14, pp.253-302, 2001. ,
Revisiting risk-sensitive MDPs: New algorithms and results, Proceedings of the 24th International Conference on Automated Planning and Scheduling (ICAPS'14, 2014. ,
Planning in probabilistic domains using a deterministic numeric planner, Proceedings of the 25th Workshop of the UK Planning and Scheduling Special Interest Group (PlanSig'06), 2006. ,
Cost-optimal planning with landmarks, Proceedings of the 21st International Joint Conference on Artificial Intelligence (IJCAI'09), pp.1728-1733, 2009. ,
How to relax a bisimulation, Proceedings of the 22nd International Conference on Automated Planning and Scheduling (ICAPS'12), pp.101-109, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00765027
PROST: Probabilistic planning based on UCT, Proceedings of the 22nd International Conference on Automated Planning and Scheduling (ICAPS'12, 2012. ,
Trial-based heuristic tree search for finite horizon MDPs, Proceedings of the 23rd International Conference on Automated Planning and Scheduling (ICAPS'13), 2013. ,
Scalable Methods and Expressive Models for Planning Under Uncertainty, 2013. ,
Sixthsense: Fast and reliable recognition of dead ends in MDPs, Proceedings of the 24th National Conference of the American Association for Artificial Intelligence (AAAI'10), 2010. ,
A theory of goal-oriented MDPs with dead ends, Proceedings of the 28th Conference on Uncertainty in Artificial Intelligence (UAI'12), pp.438-447, 2012. ,
Heuristic search for generalized stochastic shortest path MDPs, Proceedings of the 21st International Conference on Automated Planning and Scheduling (ICAPS'11, 2011. ,
SARSOP: Efficient Point-Based POMDP Planning by Approximating Optimally Reachable Belief Spaces, Robotics: Science and Systems IV, 2008. ,
DOI : 10.15607/RSS.2008.IV.009
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.149.450
Computing and Using Lower and Upper Bounds for Action Elimination in MDP Planning, Proceedings of the 7th International Symposium on Abstraction, Reformulation, and Approximation (SARA-07), 2007. ,
DOI : 10.1007/978-3-540-73580-9_20
Incremental quantitative verification for Markov decision processes, 2011 IEEE/IFIP 41st International Conference on Dependable Systems & Networks (DSN), pp.359-370, 2011. ,
DOI : 10.1109/DSN.2011.5958249
URL : https://hal.archives-ouvertes.fr/hal-00647057
PRISM 4.0: Verification of Probabilistic Real-Time Systems, Proceedings of the 23rd International on Conference Computer Aided Verification (CAV'11), pp.585-591, 2011. ,
DOI : 10.1007/3-540-45657-0_17
URL : https://hal.archives-ouvertes.fr/hal-00648035
Prottle: A probabilistic temporal planner, Proceedings of the 20th National Conference of the American Association for Artificial Intelligence (AAAI'05), pp.1181-1186, 2005. ,
Probabilistic planning vs replanning, ICAPS Workshop on the International Planning Competition: Past, Present and Future, 2007. ,
Towards faster planning with continuous resources in stochastic domains, Proceedings of the 23rd National Conference of the American Association for Artificial Intelligence (AAAI'08), pp.1049-1055, 2008. ,
Bounded real-time dynamic programming, Proceedings of the 22nd international conference on Machine learning , ICML '05, 2005. ,
DOI : 10.1145/1102351.1102423
A heuristic search approach to planning with continuous resources in stochastic domains, Journal of Artificial Intelligence Research, vol.34, issue.1, pp.27-59, 2009. ,
Operational and Algebraic Semantics of Concurrent Processes, Handbook of Theoretical Computer Science, Volume B: Formal Models and Sematics, pp.1201-1242, 1990. ,
DOI : 10.1016/B978-0-444-88074-1.50024-X
Improved non-deterministic planning by exploiting state relevance, Proceedings of the 22nd International Conference on Automated Planning and Scheduling (ICAPS'12, 2012. ,
Resource-constrained planning: A monte carlo random walk approach, Proceedings of the 22nd International Conference on Automated Planning and Scheduling (ICAPS'12), pp.181-189, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00765030
Problem Solving Methods in Artificial Intelligence, 1971. ,
Computing perfect heuristics in polynomial time: On bisimulation and merge-and-shrink abstraction in optimal planning, Proceedings of the 22nd International Joint Conference on Artificial Intelligence (IJCAI'11), pp.1983-1990, 2011. ,
Optimal planning for delete-free tasks with incremental lm-cut, Proceedings of the 22nd International Conference on Automated Planning and Scheduling (ICAPS'12, 2012. ,
Preferred operators and deferred evaluation in satisficing planning, Proceedings of the 19th International Conference on Automated Planning and Scheduling (ICAPS'09), pp.273-280, 2009. ,
Relational dynamic influence diagram language (rddl): Language description, 2010. ,
RAO*: An algorithm for chance-constrained POMDPs, Proceedings of the 30th AAAI Conference on Artificial Intelligence (AAAI'16), pp.3308-3314, 2016. ,
POMDPs make better hackers: Accounting for uncertainty in penetration testing, Proceedings of the 26th AAAI Conference on Artificial Intelligence (AAAI'12), pp.1816-1824, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00755265
Counterexample-guided Cartesian abstraction refinement, Proceedings of the 23rd International Conference on Automated Planning and Scheduling (ICAPS'13), pp.347-351, 2013. ,
Diverse and additive cartesian abstraction heuristics, Proceedings of the 24th International Conference on Automated Planning and Scheduling (ICAPS'14, 2014. ,
Focused real-time dynamic programming for MDPs: Squeezing more out of a heuristic, Proceedings of the 21st National Conference of the American Association for Artificial Intelligence (AAAI'06), pp.1227-1232, 2006. ,
Revisiting goal probability analysis in probabilistic planning, Proceedings of the 26th International Conference on Automated Planning and Scheduling (ICAPS'16, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01413035
Depth-First Search and Linear Graph Algorithms, SIAM Journal on Computing, vol.1, issue.2, pp.146-160, 1972. ,
DOI : 10.1137/0201010
Stochastic safest and shortest path problems, Proceedings of the 26th AAAI Conference on Artificial Intelligence (AAAI'12), 2012. ,
Incremental plan aggregation for generating policies in MDPs, Proceedings of the 9th International Conference on Autonomous Agents and Multiagent Systems (AAMAS'10), pp.1231-1238, 2010. ,
Extending classical planning heuristics to probabilistic planning with dead-ends, Proceedings of the 25th National Conference of the American Association for Artificial Intelligence (AAAI'11), 2011. ,
Simulation-based admissible dominance pruning, Proceedings of the 24th International Joint Conference on Artificial Intelligence (IJCAI'15), pp.1689-1695, 2015. ,
