Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : The or-pattern (p | q) matches a value v if either p or q match v. It may happen that both p and q match certain values, but that they don’t bind their variables at the same places. OCaml specifies that the left pattern p then takes precedence, but users intuitively expect an angelistic, making the “best” choice. Subtle bugs arise from this mismatch. We here describe a technique based upon pattern matrices that detect such ambiguities. This technique is implemented as a new warning in the OCaml compiler.
https://hal.inria.fr/hal-01413241 Contributor : Luc MarangetConnect in order to contact the contributor Submitted on : Friday, December 9, 2016 - 3:20:54 PM Last modification on : Wednesday, June 8, 2022 - 12:50:03 PM Long-term archiving on: : Thursday, March 23, 2017 - 10:24:16 AM
