New interface
Journal articles
Audio-Visual Speaker Diarization Based on Spatiotemporal Bayesian Fusion
Israel Gebru 1 Sileye Ba 1 Xiaofei Li 1 Radu Horaud 1
1 PERCEPTION - Interpretation and Modelling of Images and Videos
Inria Grenoble - Rhône-Alpes, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, LJK - Laboratoire Jean Kuntzmann
Abstract : Speaker diarization consists of assigning speech signals to people engaged in a dialogue. An audio-visual spatiotemporal diarization model is proposed. The model is well suited for challenging scenarios that consist of several participants engaged in multi-party interaction while they move around and turn their heads towards the other participants rather than facing the cameras and the microphones. Multiple-person visual tracking is combined with multiple speech-source localization in order to tackle the speech-to-person association problem. The latter is solved within a novel audio-visual fusion method on the following grounds: binaural spectral features are first extracted from a microphone pair, then a supervised audio-visual alignment technique maps these features onto an image, and finally a semi-supervised clustering method assigns binaural spectral features to visible persons. The main advantage of this method over previous work is that it processes in a principled way speech signals uttered simultaneously by multiple persons. The diarization itself is cast into a latent-variable temporal graphical model that infers speaker identities and speech turns, based on the output of an audio-visual association process, executed at each time slice, and on the dynamics of the diarization variable itself. The proposed formulation yields an efficient exact inference procedure. A novel dataset, that contains audio-visual training data as well as a number of scenarios involving several participants engaged in formal and informal dialogue, is introduced. The proposed method is thoroughly tested and benchmarked with respect to several state-of-the art diarization algorithms.
Complete list of metadata
https://hal.inria.fr/hal-01413403
Contributor : Perception team Connect in order to contact the contributor
Submitted on : Tuesday, January 3, 2017 - 2:40:08 PM
Last modification on : Monday, July 25, 2022 - 3:44:09 AM
Long-term archiving on: : Tuesday, April 4, 2017 - 1:41:16 PM
Gebru-TPAMI2017-final.pdf
Identifiers
Citation
Israel Gebru, Sileye Ba, Xiaofei Li, Radu Horaud. Audio-Visual Speaker Diarization Based on Spatiotemporal Bayesian Fusion. IEEE Transactions on Pattern Analysis and Machine Intelligence, 2018, 40 (5), pp.1086 - 1099. ⟨10.1109/TPAMI.2017.2648793⟩. ⟨hal-01413403⟩
Share
Metrics
Record views
838
Files downloads
367
