Split Runge-Kutta method for simultaneous equations, Journal of Research of the National Bureau of Standards Section B Mathematics and Mathematical Physics, vol.64, issue.3, p.3, 1960. ,
DOI : 10.6028/jres.064B.018
Numerical Solution of Systems of Ordinary Differential Equations Separated into Subsystems, SIAM Journal on Numerical Analysis, vol.16, issue.4, 1979. ,
DOI : 10.1137/0716045
Multirate linear multistep methods, BIT, vol.39, issue.159, pp.484-502, 1984. ,
DOI : 10.1007/BF01934907
Stability properties of backward differentiation multirate formulas, Applied Numerical Mathematics, vol.5, issue.1-2, pp.151-160, 1989. ,
DOI : 10.1016/0168-9274(89)90031-7
Stability of backward Euler multirate methods and convergence of waveform relaxation, BIT, vol.18, issue.2, pp.350-366, 1992. ,
DOI : 10.1007/BF01994887
Stability of a multi-rate method for numerical integration of ODE'S, Computers Math, Applic, vol.25, issue.2, pp.3-14, 1993. ,
Multirate ROW methods and latency of electric circuits, Applied Numerical Mathematics, vol.13, issue.1-3, pp.83-102, 1993. ,
DOI : 10.1016/0168-9274(93)90133-C
MUR8: a multirate extension of the eighth-order Dormand-Prince method, Applied Numerical Mathematics, vol.25, issue.2-3, pp.185-192, 1997. ,
DOI : 10.1016/S0168-9274(97)00058-5
Multirate Extrapolation Methods for Differential Equations with Different Time Scales, Computing, pp.173-185, 1997. ,
DOI : 10.1007/bf02684438
Multirate partitioned Runge-Kutta methods, BIT, pp.504-514, 2001. ,
A multirate time stepping strategy for stiff ordinary differential equations, BIT, pp.137-155, 2007. ,
Multirate Timestepping Methods for Hyperbolic Conservation Laws, Journal of Scientific Computing, vol.31, issue.3, pp.239-278, 2007. ,
DOI : 10.1007/s10915-007-9151-y
Multirate Explicit Adams Methods for Time Integration of Conservation Laws, Journal of Scientific Computing, vol.77, issue.2, pp.229-249, 2009. ,
DOI : 10.1007/s10915-008-9235-3
Construction and analysis of multi-rate partitioned Runge-Kutta methods, Thesis , Naval Postgraduate School, 2012. ,
On the convergence of high resolutin methods with multiple time scales for hyperbolic laws, Mathematics of Computation, vol.72, issue.243, pp.129-1250, 2002. ,
The use of domain splitting with an explicit hyperbolic solver, Computer Methods in Applied Mechanics and Engineering, vol.45, issue.1-3, pp.313-329, 1984. ,
DOI : 10.1016/0045-7825(84)90159-2
An efficient parallel implementation of explicit multirate Runge???Kutta schemes for discontinuous Galerkin computations, Journal of Computational Physics, vol.256, pp.135-160, 2014. ,
DOI : 10.1016/j.jcp.2013.07.041
Simulation of the flow past a circular cylinder in the supercritical regime by blending RANS and variational-multiscale LES models, Journal of Fluids and Structures, vol.47, pp.114-123, 2014. ,
DOI : 10.1016/j.jfluidstructs.2013.11.006
URL : https://hal.archives-ouvertes.fr/hal-01083801
Simulation of multiple blunt-body flows with a hybrid variational multiscale model, Conference on Modelling Fluid Flow (CMFF 15) The 16th International Conference on Fluid Flow Technologies, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01256084
Summary of the Tandem Cylinder Solutions from the Benchmark problems for Airframe Noise Computations-I Workshop, 49th AIAA Aerospace Sciences Meeting including the New Horizons Forum and Aerospace Exposition, pp.2011-353, 2011. ,
DOI : 10.2514/6.2011-353
Experimental Study of the Dynamic Stability of the Exomars Capsule, Proceedings of 7th European Symposium on Aerothermodynamics . ESA Communications. 7th European Symposium on Aerothermodynamics, pp.9-12 ,
