A low-diffusion MUSCL scheme for LES on unstructured grids, Computers & Fluids, vol.33, issue.9, pp.1101-1129, 2004. ,
DOI : 10.1016/j.compfluid.2003.10.002
URL : https://hal.archives-ouvertes.fr/hal-00372840
Detached???eddy simulations of the flow over a cylinder at Re = 3900 using OpenFOAM, Computers & Fluids, vol.136, pp.152-169, 2016. ,
DOI : 10.1016/j.compfluid.2016.05.031
DDES and IDDES of tandem cylinders, Proceedings of the Benchmark problems for Airframe Noise Computations BANC, 2010. ,
A dynamic subgrid???scale eddy viscosity model, Physics of Fluids A: Fluid Dynamics, vol.3, issue.7, pp.1760-1765, 1991. ,
DOI : 10.1063/1.857955
A Wall-Distance-Free k-?? Model With Enhanced Near-Wall Treatment, Journal of Fluids Engineering, vol.120, issue.3, pp.457-462, 1998. ,
DOI : 10.1115/1.2820684
Large Eddy Simulation and the variational multiscale method, Computing and Visualization in Science, vol.3, issue.1-2, pp.47-59, 2000. ,
DOI : 10.1007/s007910050051
A variational multiscale method for the large eddy simulation of compressible turbulent flows on unstructured meshes??????application to vortex shedding, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.15-16, pp.1367-1383, 2004. ,
DOI : 10.1016/j.cma.2003.12.028
URL : https://hal.archives-ouvertes.fr/hal-00372839
Numerical studies of flow over a circular cylinder at ReD=3900, Physics of Fluids, vol.12, issue.2, pp.403-417, 1999. ,
DOI : 10.1063/1.870318
A dynamical subgrid-scale eddy viscosity model with a global model coefficient, Phys. Fluids, vol.18, issue.12, 2006. ,
Towards the ultimate conservative difference scheme. IV. A new approach to numerical convection, Journal of Computational Physics, vol.23, issue.3, pp.276-299, 1977. ,
DOI : 10.1016/0021-9991(77)90095-X
A proposed modification of the Germano subgrid???scale closure method, Physics of Fluids A: Fluid Dynamics, vol.4, issue.3, p.633, 1992. ,
DOI : 10.1063/1.858280
Flow Control of Circular Cylinders with Longitudinal Grooved Surfaces, AIAA Journal, vol.40, issue.10, pp.2027-2035, 2002. ,
DOI : 10.2514/2.1535
Summary of the Tandem Cylinder Solutions from the Benchmark problems for Airframe Noise Computations-I Workshop, 49th AIAA Aerospace Sciences Meeting including the New Horizons Forum and Aerospace Exposition, pp.2011-353, 2011. ,
DOI : 10.2514/6.2011-353
Simulation of the flow past a circular cylinder in the supercritical regime by blending RANS and variational-multiscale LES models, Journal of Fluids and Structures, vol.47, pp.114-123, 2014. ,
DOI : 10.1016/j.jfluidstructs.2013.11.006
URL : https://hal.archives-ouvertes.fr/hal-01083801
Impact of dynamic subgrid-scale modeling in variational multiscale large-eddy simulation of bluff-body flows, Acta Mechanica, vol.25, issue.2, pp.3309-3323, 2014. ,
DOI : 10.1007/s00707-014-1112-6
Measurements of the Flowfield Interaction Between Tandem Cylinders, 15th AIAA/CEAS Aeroacoustics Conference (30th AIAA Aeroacoustics Conference), p.3275, 2009. ,
DOI : 10.2514/6.2009-3275
Subgrid-scale stress modelling based on the square of the velocity gradient tensor. Flow, Turbulence and Combustion 62, pp.183-200, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-00910373
Effects of Reynolds number and low-intensity free-sream turbulence on the flow around a circular cylinder, Publ. No, vol.872, 1987. ,
Fluctuating lift on a circular cylinder: review and new measurements, Journal of Fluids and Structures, vol.17, issue.1, pp.57-96, 2003. ,
DOI : 10.1016/S0889-9746(02)00099-3
Experimental and numerical studies of the flow over a circular cylinder at Reynolds number 3900, Physics of Fluids, vol.20, issue.8, 2008. ,
DOI : 10.1063/1.2957018
A DDES model with a Smagorinsky-type eddy viscosity formulation and log-layer mismatch correction, International Journal of Heat and Fluid Flow, vol.50, pp.103-113, 2014. ,
DOI : 10.1016/j.ijheatfluidflow.2014.06.002
Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-372, 1981. ,
DOI : 10.1016/0021-9991(81)90128-5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.457.5978
A New Version of Detached-eddy Simulation, Resistant to Ambiguous Grid Densities, Theoretical and Computational Fluid Dynamics, vol.140, issue.3, pp.181-195, 2006. ,
DOI : 10.1007/s00162-006-0015-0
Comments on the feasibility of LES for wings, and on a hybrid RANS/LES approach, Advances in DNS/LES, 1st AFOESR Int. Conf. On DNS/LES, pp.137-147, 1997. ,
Detached-eddy simulations past a circular cylinder, Flow, Turbulence and Combustion, vol.63, issue.1/4, pp.293-313, 1999. ,
DOI : 10.1023/A:1009901401183
Assessment of hybrid RANS/LES turbulence models for areoacoustics applications, pp.2010-4001, 2010. ,
