An algorithm to decompose noisy digital contours - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
From the previous digital contour decomposition algorithm, this paper focuses on the implementation and on the reproduction of the method linking to an online demonstration. This paper also gives improvement of the previous method with details on the intern parameter choice and shows how to use the C++ source code in other context.
Informatique
RRPR_CR_10.pdf (3.33 Mo) Télécharger le fichier
hal-01415925 , version 1 (13-12-2016)
Phuc Ngo, Hayat Nasser, Isabelle Debled-Rennesson, Bertrand Kerautret. An algorithm to decompose noisy digital contours. RRPR 2016- 1st Workshop on Reproducible Research in Pattern Recognition, Dec 2016, Cancun, Mexico. ⟨10.1007/978-3-319-56414-2_10⟩. ⟨hal-01415925⟩
190 Consultations
734 Téléchargements
