Conference papers
An Architecture for Trustworthy Open Data Services
Abstract : This paper addresses the development of trust in the use of Open Data through incorporation of appropriate authentication and integrity parameters for use by end user Open Data application developers in an architecture for trustworthy Open Data Services. The advantages of this architecture scheme is that it is far more scalable, not another certificate-based hierarchy that has problems with certificate revocation management. With the use of a Public File, if the key is compromised; it is a simple matter of the single responsible entity replacing the key pair with a new one and re-performing the data file signing process. Under this proposed architecture, the Open Data environment does not interfere with the internal security schemes that might be employed by the entity. However, this architecture incorporates, when needed, parameters from the entity, e.g. person who authorized publishing as Open Data, at the time that datasets are created/added.
Document type :
Conference papers
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01416221
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, December 14, 2016 - 11:09:17 AM
Last modification on : Wednesday, December 14, 2016 - 11:15:45 AM
Long-term archiving on: : Wednesday, March 15, 2017 - 12:51:35 PM
File
337890_1_En_11_Chapter.pdf
Identifiers
Citation
Andrew Wong, Vicky Liu, William Caelli, Tony Sahama. An Architecture for Trustworthy Open Data Services. 9th IFIP International Conference on Trust Management (TM), May 2015, Hamburg, Germany. pp.149-162, ⟨10.1007/978-3-319-18491-3_11⟩. ⟨hal-01416221⟩
Share
Metrics
Les métriques sont temporairement indisponibles
