Monocular Surface Reconstruction using 3D Deformable Part Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Our goal in this work is to recover an estimate of an object's surface from a single image. We address this severely ill-posed problem by employing a discriminatively-trained graphical model: we incorporate prior information about the 3D shape of an object category in terms of pairwise terms among parts, while using powerful CNN features to construct unary terms that dictate the part placement in the image. Our contributions are threefold: firstly, we extend the Deformable Part Model (DPM) paradigm to operate in a three-dimensional pose space that encodes the putative real-world coordinates of object parts. Secondly, we use branch-and-bound to perform efficient inference with DPMs, resulting in accelerations by two orders of magnitude over linear-time algorithms. Thirdly, we use Structured SVM training to properly penalize deviations between the model predictions and the 3D ground truth information during learning. Our inference requires a fraction of a second at test time and our results outperform those published recently in [17] on the PASCAL 3D+ dataset.
0028.pdf (774.96 Ko) Télécharger le fichier
hal-01416479 , version 1 (14-12-2016)
Stefan Kinauer, Maxim Berman, Iasonas Kokkinos. Monocular Surface Reconstruction using 3D Deformable Part Models. Geometry Meets Deep Learning Workshop in association with ECCV 2016, Oct 2016, Amsterdam, Netherlands. pp.296-308, ⟨10.1007/978-3-319-49409-8_24⟩. ⟨hal-01416479⟩
623 Consultations
354 Téléchargements
