New interface
Conference papers
Denoising and compensation of the missing wedge in cryo electron tomography
Abstract : In this study, we have addressed two important issues in cryo electron tomography images: the low signal-to-noise ratio and the presence of a missing wedge (MW) of information in the spectral domain. Indeed, according to the Fourier slice theorem, limited angle tomography results into an incomplete sampling of the Fourier domain. Therefore, the Fourier domain is separated into two regions: the known spectrum (KS) and the unknown spectrum, the latter having the shape of a missing wedge (see Figure). The proposed method tackles both issues jointly, by iteratively applying a denoising algorithm in order to fill up the MW, and proceeds as follows: [1] Excitation step: Add noise into the MW [2] Denoising step: Apply a patch-based denoising algorithm [3] Repeat steps 1 and 2, by keeping KS constant through the iterations The excitation step is used to randomly initialize the coefficients of the MW, whereas the denoising step acts as a spatial regularization. The employed denoising algorithm, which exploits the self-similarity of the image, filters out coefficient values which are dissimilar to KS, thereby keeping similar ones. By iterating these steps, we are able to diffuse the information contained in KS into the MW. An application example on experimental data can be seen on the Figure, which shows the data in both spectral and spatial domain. The data contains a spherical gold particle, deformed by MW induced artifacts: elongation of the object, side- and ray-artifacts. From the residue image it can be seen that noise and MW artifacts have been reduced, while preserving the details of the image. Experiments are being performed to verify if particle detection and alignment are enhanced by using the method as a pre-processing step.
Complete list of metadata
https://hal.inria.fr/hal-01416801
Contributor : Charles Kervrann Connect in order to contact the contributor
Submitted on : Wednesday, December 14, 2016 - 6:44:31 PM
Last modification on : Saturday, June 25, 2022 - 7:45:54 PM
Identifiers
  • HAL Id : hal-01416801, version 1
Collections
Citation
Emmanuel Moebel, Charles Kervrann. Denoising and compensation of the missing wedge in cryo electron tomography. 16th European Microscopy Congress, European Microscopy Society, Aug 2016, Lyon, France. ⟨hal-01416801⟩
Share
Metrics
Record views
170
