Archiving scientific data, ACM Transactions on Database Systems, vol.29, issue.1, pp.2-42, 2004. ,
DOI : 10.1145/974750.974752
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.6862
Fifty years of graph matching, network alignment and network comparison, Information Sciences, vol.346, issue.347, pp.180-197, 2016. ,
DOI : 10.1016/j.ins.2016.01.074
Data integration: The teenage years, International Conference on Very Large Data Bases (VLDB), pp.9-16, 2006. ,
IUPHAR-DB: the IUPHAR database of G protein-coupled receptors and ion channels, Nucleic Acids Research, vol.37, issue.Database, pp.680-685, 2009. ,
DOI : 10.1093/nar/gkn728
Everything you always wanted to know about blank nodes, Web Semantics: Science, Services and Agents on the World Wide Web, pp.42-69, 2014. ,
DOI : 10.1016/j.websem.2014.06.004
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.665.2484
A lower bound for the edit-distance problem under an arbitrary cost function, Information Processing Letters, vol.27, issue.6, pp.319-321, 1988. ,
DOI : 10.1016/0020-0190(88)90220-7
A binary linear programming formulation of the graph edit distance, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.28, issue.8, pp.1200-1214, 2006. ,
DOI : 10.1109/TPAMI.2006.152
Frameworks for entity matching: A comparison, Data & Knowledge Engineering, vol.69, issue.2, pp.197-210, 2010. ,
DOI : 10.1016/j.datak.2009.10.003
The Hungarian method for the assignment problem, Naval Research Logistics, vol.52, issue.1, pp.7-21, 2005. ,
DOI : 10.1002/nav.20053
Tasks that require, or can benefit from, matching blank nodes. CoRR, abs, 1410. ,
Modeling sample variables with an Experimental Factor Ontology, Bioinformatics, vol.26, issue.8, pp.1112-1118, 2010. ,
DOI : 10.1093/bioinformatics/btq099
URL : https://hal.archives-ouvertes.fr/hal-00721833
Similarity flooding: a versatile graph matching algorithm and its application to schema matching, Proceedings 18th International Conference on Data Engineering, pp.117-128, 2002. ,
DOI : 10.1109/ICDE.2002.994702
Three Partition Refinement Algorithms, SIAM Journal on Computing, vol.16, issue.6, pp.973-989, 1987. ,
DOI : 10.1137/0216062
High-level change detection in RDF(S) KBs, ACM Transactions on Database Systems, vol.38, issue.1, p.1, 2013. ,
DOI : 10.1145/2445583.2445584
Data cleaning: Problems and current approaches, IEEE Data Engineering Bulletin, vol.23, issue.4, pp.3-13, 2000. ,
Large-scale bisimulation of RDF graphs, Proceedings of the Fifth Workshop on Semantic Web Information Management, SWIM '13, p.1, 2013. ,
DOI : 10.1145/2484712.2484713
Blank Node Matching and RDF/S Comparison Functions, International Semantic Web Conference (ISWC), pp.591-607, 2012. ,
DOI : 10.1007/978-3-642-35176-1_37
Bounds for the String Editing Problem, Journal of the ACM, vol.23, issue.1, pp.13-16, 1976. ,
DOI : 10.1145/321921.321923
On Computing Deltas of RDF/S Knowledge Bases, ACM Transactions on the Web, vol.5, issue.3, 2011. ,
DOI : 10.1145/1993053.1993056
