Multiple Order-Preserving Hash Functions for Load Balancing in P2P Networks
Hash functions are at the heart of data insertion and retrieval in DHT-based overlays. However, a standard hash function destroys the natural ordering of data. To perform efficient range queries processing, in a minimum number of hops, more and more systems opt for an order-preserving hash function to place data. Unlike a standard hash function, this technique cannot evenly distribute data among peers. In this paper, we propose a novel approach to improve the data dissemination using several order-preserving hash functions. We describe a protocol that allows an overloaded peer to change its hash function at run-time. Then, we show that all peers should not necessarily use the same hash function in an overlay to insert or look for an item. Finally, we demonstrate through simulations that this strategy greatly improves the dissemination of data items. As this technique does not require any overall coordination, it is well suited to overloaded P2P systems facing unstable topologies. To our knowledge, this is the first load balancing solution using multiple order-preserving hash functions in structured overlays.
Multiple Order-Preserving Hash Functions for Load Balancing in P2P Networks.pdf (2.07 Mo)
Télécharger le fichier
