A Scheduling Method With Considering Nesting for Sheet Metal Processing, ASME/ISCIE 2012 International Symposium on Flexible Automation, pp.2012-7197, 2012. ,
DOI : 10.1115/ISFA2012-7197
Study on nesting scheduling for sheet metal processing (Improvement of nesting method by parts reallocation), Transactions of the JSME (in Japanese), vol.81, issue.825, pp.81-95, 2015. ,
DOI : 10.1299/transjsme.14-00640
Two-dimensional packing problems: A survey, European Journal of Operational Research, vol.141, issue.2, pp.241-252, 2002. ,
DOI : 10.1016/S0377-2217(02)00123-6
Orthogonal Packings in Two Dimensions, SIAM Journal on Computing, vol.9, issue.4, pp.846-855, 1980. ,
DOI : 10.1137/0209064
The Two-Stage Assembly Scheduling Problem: Complexity and Approximation, Operations Research, vol.43, issue.2, pp.346-355, 1995. ,
DOI : 10.1287/opre.43.2.346
A PSO and a Tabu search heuristics for the assembly scheduling problem of the two-stage distributed database application, Computers & Operations Research, vol.33, issue.4, pp.1056-1080, 2006. ,
DOI : 10.1016/j.cor.2004.09.002
A decision-making approach for nesting scheduling: A textile case, International Journal of Production Research, vol.38, issue.17, pp.4555-4564, 2000. ,
DOI : 10.1080/00207540050205299
Integrated sheet-metal production planning for laser cutting and bending, International Journal of Production Research, vol.4, issue.2, pp.369-383, 2007. ,
DOI : 10.1016/j.ijpe.2004.12.017
