Cost-Aware Fronthaul Rate Allocation to Maximize Benefit of Multi-User Reception in C-RAN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aiming to throughput enhancement in future mobile networks, dense deployment of wireless access points (APs) is intended. Spectral efficiency on the uplink can be improved via joint processing of users located in areas covered by several APs. Thanks to centralized processing of such users enabled by today’s Cloud Radio Access Network (C-RAN) architecture, low-latency multi-cell cooperation becomes possible. However, the price to pay for benefiting from its advantages is the cost of transferring data from distributed access points to the data-center through limited-capacity fronthaul links. A mobile network operator using C-RAN would have the objective to maximize data transmission rates with lowest possible fronthaul rate. We consider in this work the optimal tradeoff between the amount of fronthaul allocated and the sum-rate of each user group in a multiple access scheme, where the wireless resource is reused among the user groups. By performing low-complexity joint reception of signals quantized according to attributed fronthaul rate, we can maximize the benefit of uplink transmission in C-RAN despite constrained fronthaul links. An improvement of 10% can be observed in a usual configuration.
Conf_fh_alloc_optim_201612.pdf (330.38 Ko) Télécharger le fichier
hal-01417703 , version 1 (15-12-2016)
hal-01417703 , version 2 (20-01-2017)
  • HAL Id : hal-01417703 , version 1
Dora Boviz, Chung Shue Chen, Sheng Yang. Cost-Aware Fronthaul Rate Allocation to Maximize Benefit of Multi-User Reception in C-RAN. IEEE Wireless Communications and Networking Conference (WCNC), Mar 2017, San Francisco, United States. ⟨hal-01417703v1⟩
404 Consultations
268 Téléchargements
