Quantification in Frame Semantics with Binders and Nominals of Hybrid Logic
This paper aims at integrating logical operators into frame-based semantics. Frames are semantic graphs that allow to capture lexical meaning in a fine-grained way but that do not come with a natural way to integrate logical operators such as quantifiers. The approach we propose starts from the observation that modal logic is a powerful tool for describing relational structures, hence frames. We use its hybrid logic extension in order to incorporate quantification and thereby allow for inference and reasoning. We integrate our approach to a type theoretic compositional semantics, formulated within Abstract Categorial Grammars. We also show how the key ingredients of hybrid logic, nominals and binders, can be used to model semantic coercion, such as the one induced by the begin predicate. In order to illustrate the effectiveness of the proposed syntax-semantics interface, all the examples can be run and tested with the Abstract Categorial Grammar development toolkit.
147-1407-1-PB.pdf (340.55 Ko)
Télécharger le fichier
quantification-and-frames.zip (3.12 Ko)
