Conference papers
3D imaging for underfoliage targets using L-band multibaseline polinsar data and sparse estimation methods
Abstract : SAR imaging of concealed targets beneath the canopies has to face a complex mixture of diverse scattering mechanisms. To characterize this complex scattering environment, nonpara-metric tomographic estimators are more robust to focusing artefacts but limited in resolution. Parametric tomographic estimators provide better vertical resolution but fail to adequately characterize continuously distributed volumetric scat-terers such as forest canopies. To overcome these limitations, this paper addresses a new wavelet-based sparse estimation method for 3D imaging and characterization for underfoliage objects. The effectiveness of this new approach is demonstrated by using L-band Multi-Baseline PolInSAR Data over Dornstetten, Germany.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01418435
Contributor : Yue Huang Connect in order to contact the contributor
Submitted on : Monday, December 19, 2016 - 12:10:17 PM
Last modification on : Wednesday, April 27, 2022 - 3:54:36 AM
Long-term archiving on: : Monday, March 20, 2017 - 6:41:53 PM
File
IGARSS_Yhuang.pdf
Identifiers
Citation
Yue Huang, Jacques Levy Vehel, Laurent Ferro-Famil, Andreas Reigber. 3D imaging for underfoliage targets using L-band multibaseline polinsar data and sparse estimation methods. IGARSS 2016 - IEEE International Geoscience and Remote Sensing Symposium, Jul 2016, Beijing, China. ⟨10.1109/igarss.2016.7729373⟩. ⟨hal-01418435⟩
Share
Metrics
Record views
161
Files downloads
154
