Computing solutions of linear Mahler equations
Abstract : Mahler equations relate evaluations of the same function $f$ at iterated $b$th powers of the variable. They arise in particular in the study of automatic sequences and in the complexity analysis of divide-and-conquer algorithms. Recently, the problem of solving Mahler equations in closed form has occurred in connection with number-theoretic questions. A difficulty in the manipulation of Mahler equations is the exponential blow-up of degrees when applying a Mahler operator to a polynomial. In this work, we present algorithms for solving linear Mahler equations for series, polynomials, and rational functions, and get polynomial-time complexity under a mild assumption. Incidentally, we develop an algorithm for computing the gcrd of a family of linear Mahler operators with nonzero constant terms.
Type de document :
Pré-publication, Document de travail
2016
Liste complète des métadonnées
Littérature citée [16 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01418653
Contributeur : Frédéric Chyzak <>
Soumis le : vendredi 16 décembre 2016 - 18:03:11
Dernière modification le : jeudi 18 octobre 2018 - 14:14:20
Document(s) archivé(s) le : mardi 21 mars 2017 - 11:12:56
Fichier
mahlersols.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01418653, version 1
Citation
Frédéric Chyzak, Thomas Dreyfus, Philippe Dumas, Marc Mezzarobba. Computing solutions of linear Mahler equations . 2016. 〈hal-01418653v1〉
Métriques
Consultations de la notice
283
Téléchargements de fichiers
58
